QoS priority question
After adding the bandwidth command to the interface I see that amount of bandwidth allocated to VOICE is only 5000 kbps. Should this not be 10000 kbps?  or am I calculating it wrong?
interface GigabitEthernet0/1
bandwidth 40000
no ip address
load-interval 30
duplex full
speed 100
max-reserved-bandwidth 100
service-policy output QOS
Class-map: VOICE (match-all)
          0 packets, 0 bytes
          30 second offered rate 0 bps, drop rate 0 bps
          Match:  dscp ef (46)
          Priority: 25% (5000 kbps), burst bytes 125000, b/w exceed drops: 0
Please remember to select a correct answer and rate helpful posts
joelgooding
hello,
Did you manually enter the value of priority 5000kbps? if not can you do so and repost the show run part result.
Joel
_______________________________
Please rate helpful posts and answered questions!
Joel _______________________________ Please rate helpful posts and answered questions!
