QOS Problem
emphillips00
Hi all,
I have a small MPLS with limited bandwidth. I am trying to create a QOS policy to guarentee 512kb/sec for my voice traffic, 64kb/sec for ping and telnet (to always make sure I can telnet and test connectivity to my routers), 50% of the remaining to my business system, 25% of the remaining to email, 24% to everything else, and only 1% for file-sharing programs like kazaa.
I have tried the following QOS policy on my routers. It looks good to me, but as soon as I put it on the interface ping responses jump from ~40ms to sometimes as much as 1000ms. Can anyone see what I am doing wrong?
ip access-list ext ACLimportant
remark ACL to give low bandwidth important traffic higher priority
permit icmp any any
permit tcp any any eq telnet
ip access-list ext ACLqad
permit ip any host 10.1.1.7
permit ip host 10.1.1.7 any
ip access-list ext ACLemail
remark ACL To and From Email servers for QOS
permit ip any host 10.1.1.8
permit ip host 10.1.1.8 any
permit ip any host 10.2.1.2
permit ip host 10.2.1.2 any
permit ip any host 10.2.1.18
permit ip host 10.2.1.18 any
class-map match-any qad
match access-group name ACLqad
class-map match-any email
match access-group name ACLemail
class-map match-any voice
match dscp ef
class-map match-any badtraffic
match protocol gnutella
match protocol kazaa2
match protocol napster
class-map match-any important
match access-group name ACLimportant
policy-map pmap_mpls
class voice
priority 512
class important
set dscp af21
priority 64
class qad
set dscp af21
bandwidth remaining percent 50
class email
set dscp af11
bandwidth remaining percent 25
class badtraffic
set dscp 0
bandwidth remaining percent 1
random-detect dscp-based
class class-default
set dscp 0
bandwidth remaining percent 24
interface s0/0/0
service-policy output pmap_mpls
Thanks!
Eric
mheusinger
Level 10
Level 10
I would not recommend the "priority" queue but to use "bandwidth" instead. This should give more predictable behaviour as PQ comes with a policer, which might adversely affect your traffic.
So try
class voice
priority 512
class important
set dscp af21
bandwidth percent remaining 10
Also make sure the marking AF21 is used properly on all other components in your network. Delays could arise somewhere else in the network. In addition be aware, that this policy will handle TRANSIENT traffic, i.e. NOT generated by the router itself.
To prioritize local traffic use a local policy "ip local policy route-map". With the route-map describe the traffic through an ACL and set IP precedence. In your QoS policy use the marking to sort the traffic into the relevant class.
Regards, Martin
[Edit] The bandwidth percent should not exceed 100% in total AND - most important - refers to the interface bandwidth. Serials are defaulting to T1 (!). Make sure you configure the bandwidth correctly on your interface:
interface s0/0/0
bandwidth 1000 !replace with real bandwith of your access line.
mheusinger
Level 10
Level 10
So try
class voice
priority 512
class important
set dscp af21
Regards, Martin
interface s0/0/0
Hi Martin,
Thanks a bunch for the help. I put the "important" traffic in the same class as my business application's class, so it gets a big percentage and not a priority queue, and that seems to be working much better.
I don't quite understand it though... There is not much ICMP or telnet traffic on my network. My understanding is the priority queue is a minimum AND maximum (ie... if 65kb/sec of ICMP traffic tried to flow, it would drop 1kb/sec). But I have never used two priority queues, so I don't know...
And thank you for reminding me about the bandwidth and transient issue... I did happen to remember those from my CCNP studies, but it is always good to keep that in mind.
We shall see how the new queueing works!
Thanks!
Eric
