QOS query
mukundh86
Hi all
I wanted to verify my understanding of QOS and make sure that I am on the right page with respect to it.
Is it correct to say that QOS kicks in only when there is 100% utilization of bandwidth? If so, how does the router know about 100% utilization ?
Mukundh
8 Replies 8
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
No, it's when offered rate exceeds 100%.
When a queue forms.
Basically, QoS does "something" beyond just FIFO queuing.
Thanks a lot for your replies. Shall have a look at the Q&A doc in weekend . Didn have time to look into it as of now
Marwan ALshawi
When you have a policy map for qos applied on an interface and this interface get congested/fully utilized the qos policy will kiksin
How the policy knows the interface congested ? This through tow ways
Referencing the interface bandwidth ( u can change it using bandwidth command )
Or using parent policy with shaping
If helpful rate
Disclaimer
Posting
Just wanted to clarify, the bandwidth statement, correctly set, can be used to determine interface/policy load but a QoS service policy will not queue packets (unless using percent based shapers) based on the bandwidth statement.  (NB: the bandwidth statement can also influence class weights which can be important if your mixing absolute and relative bandwidth statements in CBWFQ class statements.)
If for example, you set the bandwidth statement to 10x actual physical interface bandwidth, 100% actual interface usage will only show as 10% usage but a CBWFQ service policy will queue and treat packets as the policy defines.
Conversely, if bandwidth statement is set to 1/10 of actual interface bandwidth, 50% actual interface usage may show as 500% usage but a CBWFQ policy will not resequence packets (again w/o a shaper).
I have another query. Lets say I have a policy map configured where RTP voice packets are marked with EF and 60% priority and RTCP is mareked with cs3 with 15% priority and the policy map is configured on outbound interface. Is it so that the RTP and RTCP are always given 60% and 15% of the bandwidth irrespective of whether the bandwidth is 100% utilized or not.
Disclaimer
Posting
No, they are not.
PS:
Recently, a thread on LLQ (priority) processing.  See Peter's LLQ test results at end of:
https://supportforums.cisco.com/message/3424125
Thanks for this thread..Highly useful...
