QoS Question / match protocol citrix
mlpalmer
What port(s) does / do the keyword "citrix" match?  Where is this defined?  Is it editable?
Thanks, Mike.
12.4 series code on 28xx routers
'show ip nbar port-map' should reveal the ports each protcol is using to classify traffic.
In global config mode 'ip nbar port-map' may be used to modify the ports being used.
The 'ip nbar custom' command can also be handy.
http://www.cisco.com/en/US/partner/docs/ios/qos/command/reference/qos_book.html
Christopher Gatlin
http://travelingtech.net
David Hailey
Take a look here.  It's a pretty good resource: support.citrix.com/servlet/...102.../Cisco_Networking_Integratio.pdf (Also attached).
With match protocol citrix, you can optionally specify individual applications.  If you leave it as-is, then it establishes all Citrix traffic as successful match  criteria.  The various apps and ports are outlined in the attached PDF.
Hailey
Please rate helpful posts!
That doesn't sound right.  80 and 443 are in the port table of the pdf.
Mike.
Christopher Gatlin
Host#sh ip nbar port-map
(edit)
port-map citrix                   udp 1604
port-map citrix                   tcp 1494
Thanks, answered my question.
Mike
