QOS Question ?
Andrew Melsom
Hello All
Hope you can help,I am trying to implement QOS on one of my companys WAN links as, i am trying to limit the bandwith used by our SAN replecating to diffrent sites, The network used a VLAN interface tied to a Fastethernet interface, what i want to try is implement traffic policing or shaping on this vlan to limit the amount to 50%. Is this possible if so can anyone help me with the configuration ?
Thank you
21 Replies 21
DR-RTR-1801-1#sho policy-map int vlan 40
Vlan40
  Service-policy output: LIMIT_BW
    Class-map: LIMIT_BW(match-all)
      39937160 packets, 59861135486 bytes
      5 minute offered rate 87813000 bps, drop rate 0 bps
      Match: access-group 75
      Traffic Shaping
           Target/Average   Byte   Sustain   Excess    Interval  Increment
             Rate           Limit  bits/int  bits/int  (ms)      (bytes)
           512000/512000    3200   12800     12800     25        1600
        Adapt  Queue     Packets   Bytes     Packets   Bytes     Shaping
        Active Depth                         Delayed   Delayed   Active
        -      0         0         0         0         0         no
    Class-map: class-default (match-any)
      1707181 packets, 299892247 bytes
      5 minute offered rate 550000 bps, drop rate 0 bps
      Match: any
Still at 100% of BW in affraid.
Andy
Okay...Can you post the complete config for the router? Class map, policy map, access-list (you may want to try an extended acl in place of the standard that you have now), and all interface configurations including svis.
What ios version are you on?
HTH, John *** Please rate all useful posts ***
DR-RTR-1801-1#show running-config
Building configuration...
Current configuration : 9676 bytes
! Last configuration change at 15:12:05 BST Wed Oct 17 2012 by **********
! NVRAM config last updated at 11:25:25 BST Fri Oct 12 2012 by **********
version 12.4
service password-encryption
hostname DR-RTR-1801-1
boot-start-marker
boot-end-marker
enable secret ***************
aaa new-model
aaa group server radius rad_admin
server *************** auth-port 1812 acct-port 1813
aaa authentication login default group rad_admin local
aaa authentication login eap_methods group rad_eap
aaa authentication login if_needed local
aaa authentication login conmethod local enable
aaa authorization exec default group rad_admin if-authenticated
aaa session-id common
clock timezone gmt 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 1:00
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address ***************
ip dhcp pool LOCAL-LAN
   import all
   network *************** 255.255.255.0
   dns-server ***************
   domain-name ***************
   default-router ***************
   lease 3
ip domain name ***************
ip name-server ***************
isdn switch-type basic-net3
username ****** privilege 15 password 7 ***************
archive
log config
  hidekeys
ip telnet source-interface Vlan1
ip tftp source-interface Vlan1
ip ssh authentication-retries 4
ip ssh version 2
class-map match-all LIMIT_BW
match access-group 75
policy-map LIMIT_BW
class LIMIT_BW
  shape average 512000
interface ATM0
no ip address
dsl operating-mode auto
interface BRI0
no ip address
encapsulation ppp
shutdown
dialer pool-member 2
isdn point-to-point-setup
isdn voice-priority always
isdn incoming-voice modem
ppp authentication pap
ppp multilink
interface FastEthernet0
no ip address
duplex auto
speed auto
interface FastEthernet1
description ***************
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description DR Network
switchport access vlan 141
interface FastEthernet5
description Etherflow
switchport access vlan 40
bandwidth 100000
interface FastEthernet6
shutdown
interface FastEthernet7
shutdown
interface FastEthernet8
shutdown
interface Vlan1
description Network
no ip address
ip route-cache policy
ip route-cache flow
shutdown
interface Vlan40
ip address 192.168.40.42 255.255.255.0
ip nbar protocol-discovery
ip route-cache flow
ip ospf authentication message-digest
ip ospf message-digest-key 1 md5
ip ospf hello-interval 2
ip ospf dead-interval 6
service-policy output LIMIT_BW
interface Vlan141
ip address 192.168.2.0 255.255.255.0
ip route-cache flow
interface Dialer1
no ip address
router ospf 1
log-adjacency-changes
area 0 authentication message-digest
passive-interface default
no passive-interface Vlan40
no passive-interface Vlan141
network 192.168.2.0 0.0.0.255 area 0
network 192.168.40.0 0.0.0.255 area 0
ip forward-protocol nd
no ip forward-protocol udp tftp
no ip forward-protocol udp nameserver
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
ip forward-protocol udp bootpc
ip flow-cache timeout active 1
ip flow-export source Vlan141
ip flow-export version 5
ip flow-export destination 192.168.128.16 9996
ip http server
ip http authentication aaa
ip http secure-server
ip radius source-interface Vlan1
access-list 75 permit 192.168.2.21
access-list 101 permit esp any any
access-list 101 permit ip any any
snmp-server community ********** RO
snmp-server community ********** RW
snmp-server ifindex persist
snmp-server contact
route-map vl142-policy permit 10
description
match ip address vlan142
set ip next-hop 192.168.40.41
control-plane
line con 0
exec-timeout 120 0
login authentication conmethod
stopbits 1
line aux 0
exec-timeout 120 0
stopbits 1
line vty 0 4
exec-timeout 120 0
password 7 1414131804013D
transport input telnet ssh
webvpn context Default_context
ssl authenticate verify all
no inservice
end
What ios are you on? "show ver"
DR-RTR-1801-1#show ver
Cisco IOS Software, C180X Software (C180X-ADVIPSERVICESK9-M), Version 12.4(15)T13, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 07-Apr-10 09:56 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YH8, RELEASE SOFTWARE (fc2)
DR-RTR-1801-1 uptime is 6 days, 23 hours, 29 minutes
System restarted at 08:26:41 BST Thu Oct 11 2012
System image file is "flash:c180x-advipservicesk9-mz.124-15.T13.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1801 (MPC8500) processor (revision 0x400) with 118784K/12288K bytes of memory.
Processor board ID FHK112616Q3, with hardware revision 0000
9 FastEthernet interfaces
1 ISDN Basic Rate interface
1 ATM interface
31360K bytes of ATA CompactFlash (Read/Write)
I'd recommend updating the ios on the router. I didn't find a specific issue, but there are several issues with qos that were fixed in later versions.
Hello John
We have tested version 15.0 and this causes the routers to just restart so we can not risk this on our main WAN router at this time.
Thanks for your help
Andy
