QOS Question ?
Andrew Melsom
Hello All
Hope you can help,I am trying to implement QOS on one of my companys WAN links as, i am trying to limit the bandwith used by our SAN replecating to diffrent sites, The network used a VLAN interface tied to a Fastethernet interface, what i want to try is implement traffic policing or shaping on this vlan to limit the amount to 50%. Is this possible if so can anyone help me with the configuration ?
Thank you
I'd recommend updating the ios on the router. I didn't find a specific issue, but there are several issues with qos that were fixed in later versions.
HTH, John *** Please rate all useful posts ***
21 Replies 21
Andrew Melsom
As no one has replied to this, i can only guess my description is to poor.
What i want to to is limit the amount of bandwith Server1 uses across our WAN link between our two sites, currenty we have a 100Mb link and this is using 100% of this and i would like to limit this to 50%. We have a cisco 1801 router using FA 4 as a SVI linked to VLAN 141 and (this is the internal side of the network). Then we have FA 5 witch is a SVI linked to VLAN 40 (this is the outside that sends traffic across our WAN). If i create a policy-map and implement traffic policing on the FA inerfaces nothing happens. If i try to apply the policy-map to a VLAN the router comes back "configuration failed !".
access-list 75 permit 192.168.2.21
Show Policy-Map
Policy Map LIMIT_BW
    Class LIMIT_BW
     police cir 52428500 bc 1638390
       conform-action transmit
       exceed-action drop
Show Class-Map
Class Map match-all LIMIT_BW (id 1)
   Match access-group  75
Any ideas ?
Thanks Again
Andrew,
If you're trying to control traffic between 2 endpoints, you should shape the traffic outbound. Try this on your wan interface:
class-map LIMIT_BW
match access-group 75
policy-map LIMIT_BW
class LIMIT_BW
shape average percent 50
Apply it on the wan interface outbound:
int
service-policy output LIMIT_BW
You'll need to do this on both sides of the link.
HTH,
John
Hello John
i have applied this both ends and the traffic is still usin 100% of the BW any ideas ?
  Policy Map LIMIT_BW_TO_WEYBRIDGE
    Class LIMIT_BW_TO_WEYBRIDGE
      Traffic Shaping
         Average Rate Traffic Shaping
         CIR 50 (%) Max. Buffers Limit 1000 (Packets)
Andy
Can you post "show policy interface", "sh run class-map", "sh run policy-map" and the acl that you're using to match on?
DR-RTR-1801-1#show policy-map int fa 5
FastEthernet5
  Service-policy output: LIMIT_BW
    Class-map: LIMIT_BW (match-all)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group 75
      Traffic Shaping
           Target/Average   Byte   Sustain   Excess    Interval  Increment
             Rate           Limit  bits/int  bits/int  (ms)      (bytes)
               50 (%)                0 (ms)      0 (ms)
         50000000/50000000  312500 1250000   1250000   25        156250
        Adapt  Queue     Packets   Bytes     Packets   Bytes     Shaping
        Active Depth                         Delayed   Delayed   Active
        -      0         0         0         0         0         no
    Class-map: class-default (match-any)
      1 packets, 377 bytes
      Match: any
What device do you have this policy configured on? The 1801 or is it on the switch?
This is on the 1801 router
I'm assuming the following:
Server ---> switch ---> (lan)Router(wan)
Is the above correct? Are you natting on the 1801?
Can you post "show access-list 75"?
*** Edit ***
Can you post the running config from the router...mask out the public IPs please...
Yes you are correct with the Server ---> switch ---> (lan)Router(wan), We are not natting across our WAN.
DR-RTR-1801-1#show ip access-lists 75
Standard IP access list 75
    10 permit 192.168.2.21 (8944319 matches)
Andy
If you're not natting, there's simply no reason that I can think of that wouldn't match on this policy. What ios version are you running? Have you looked for bugs?
Is F5 your wan interface that has the wan address on it?
Hi john
Not sure if this helps ?
interface Vlan40
description Etherflow to ********
ip address 192.168.40.42 255.255.255.0
ip nbar protocol-discovery
ip route-cache flow
ip ospf authentication message-digest
ip ospf message-digest-key 1 md5 7 *******************
ip ospf hello-interval 2
ip ospf dead-interval 6
interface FastEthernet5
description Etherflow to **********
switchport access vlan 40
bandwidth 100000
Try moving the service policy off of fa5 to vlan 140 svi and you should start getting hits...
HTH,
John
DR-RTR-1801-1#sho policy-map interface vlan 40
Vlan40
      575024 packets, 861903336 bytes
      5 minute offered rate 19344000 bps, drop rate 0 bps
      Traffic Shaping
        -      0         0         0         0         0         no
      10184 packets, 1850703 bytes
      5 minute offered rate 52000 bps, drop rate 0 bps
      Match: any
Still using 100 % of the BW
Andy
Hey! We're getting closer At least we're seeing hits on the class map where you weren't before...
Try removing "shape average percent 50" and replace with half of your bandwidth. Let's say you have a 1Mb circuit, half of that would be 512k:
shape average 512000
Then see if you're shaping... Your "Shaping Active" line should say Yes
