I hope someone here can answer my questions. I have asked some of the CCIE's on my team and opened a TAC case, but neither option provided solid answers.
The short version of my question is this: what does "5 minute rate XX bps" mean in the context of the "show policy-map interface x/x" command?
In addition I would like to find out what unit of measurement, I.E. bits, bytes etc., is used in the output "cir 768000" for the police command in the class map .
The full output of show policy-map and show version commands are below.
Thanks in advance for any help you can provide.
rtrxxxx#show policy-map interface s0/0/0:0
Serial0/0/0:0
Service-policy output: QoS_OUT
Class-map: Express_Forward (match-any)
863884 packets, 66581508 bytes
5 minute offered rate 7000 bps, drop rate 0 bps
Match: access-group name VOIP-BEARER
5 minute rate 7000 bps
Queueing
queue limit 64 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 863884/66353276
bandwidth remaining 20% (307 kbps)
Class-map: Gold (match-any)
174353 packets, 105051208 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group name EPS
22616 packets, 2290071 bytes
5 minute rate 0 bps
Match: access-group name RX
151737 packets, 102761137 bytes
5 minute rate 0 bps
Queueing
(pkts output/bytes output) 171583/104927763
bandwidth remaining 10% (153 kbps)
Class-map: Silver (match-any)
1426952 packets, 262747525 bytes
5 minute offered rate 2000 bps, drop rate 0 bps
Match: access-group name MAINFRAME
174712 packets, 61240491 bytes
5 minute rate 0 bps
Match: access-group name KRONOS
181558 packets, 34240271 bytes
5 minute rate 0 bps
Match: access-group name EMAIL
755599 packets, 97267234 bytes
5 minute rate 2000 bps
Match: access-group name VOIP-CONTROL
9284 packets, 1135517 bytes
5 minute rate 0 bps
Match: access-group name LOGIXWEB
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name GRINDLOG
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name CITRIX
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name CORP_WEB
305799 packets, 68864012 bytes
5 minute rate 0 bps
Queueing
(queue depth/total drops/no-buffer drops) 0/514/0
(pkts output/bytes output) 1420934/261435436
bandwidth remaining 50% (768 kbps)
Class-map: Bronze (match-any)
639010 packets, 127794658 bytes
Match: access-group name AUTH
531274 packets, 119388866 bytes
Match: access-group name DHCP
499 packets, 177340 bytes
5 minute rate 0 bps
Match: access-group name DNS
107237 packets, 8228452 bytes
5 minute rate 0 bps
Queueing
(pkts output/bytes output) 638694/127446294
bandwidth remaining 5% (76 kbps)
Class-map: Scavenger (match-any)
124834 packets, 17220523 bytes
5 minute offered rate 5000 bps, drop rate 0 bps
Match: protocol ssh
45906 packets, 7259947 bytes
5 minute rate 5000 bps
Match: access-group name PING
78928 packets, 9960576 bytes
5 minute rate 0 bps
Queueing
(pkts output/bytes output) 124794/14898062
Class-map: POLICE_STATE (match-any)
361142 packets, 504176191 bytes
Match: access-group name TSMSTRICT
5 minute rate 0 bps
police:
cir 768000 bps, bc 24000 bytes, be 1500 bytes
conformed 351211 packets, 490035216 bytes; actions:
transmit
exceeded 2566 packets, 3653984 bytes; actions:
drop
violated 7365 packets, 10487003 bytes; actions:
drop
conformed 0 bps, exceed 0 bps, violate 0 bps
Class-map: class-default (match-any)
25516182 packets, 12778536664 bytes
5 minute offered rate 141000 bps, drop rate 0 bps
Match: any
Queueing
(queue depth/total drops/no-buffer drops) 4/5143/0
(pkts output/bytes output) 25414437/13370803818
rtrxxxx#show ver
Cisco IOS Software, 3800 Software (C3845-ADVIPSERVICESK9-M), Version 12.4(24)T4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 03-Sep-10 10:00 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
rtr8387a uptime is 2 years, 2 days, 5 hours, 21 minutes
System returned to ROM by Reload Command
System restarted at 10:38:14 UTC Wed Jun 27 2012
System image file is "flash:c3845-advipservicesk9-mz.124-24.T4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3845 (revision 1.0) with 471039K/53248K bytes of memory.
Processor board ID FTX1150A072
2 Gigabit Ethernet interfaces
1 Serial interface
2 terminal lines
1 Channelized/Clear T1/PRI port
1 Virtual Private Network (VPN) Module
6 Voice FXS interfaces
1 cisco Integrated Service Engine(s)
Cisco WLAN Controller 5.0.148.0 in slot 1
1 cisco Integrated Service Engine-2(s)
Cisco Wide Area Application Services Software 4.3.5a (b1 Oct 17 2011 13:57:15) in slot 2
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
126976K bytes of ATA System CompactFlash (Read/Write)
Hello bbiddings,
1) 5 minute offered rate 5000 bps, drop rate 0 bps
This means that the rate is actually an average over the last 5 minutes. Interface counters are moving average over time with an exponential law that says something like:
average= current rate*exp(-t/T) + (1- exp(-t/T))*old rate value
where T is actually 5 minutes.
in interface configuration you can change T as low as 30 seconds with load-interval 30 interface command.
I cannot test now but it is possible that load-interval change also the time interval for sh policy-map int output.
The property of this kind of average is that it takes four intervals to reach a steady value.
2) CIR 768000
These are bit per second and the Committed information rate is the rate for conforming packets as measured in a token bucket algorithm used by the policer
Hope to help
Giuseppe
Giuseppe,
Thank you for taking the time to reply.
I am still not sure about the output below. You defined the 5 minute offered rate. I am looking for more info on the "5 minute rate xxx bps". The two appear to be different some how. See below.. in the output of show policy-map interface... under one of the match statements, there is a line that says "5 minute rate xxx bps"
Hello bbiddings,
if we examine the output for the whole class silver we see:
5 minute rate 0 bps
5 minute rate 0 bps
5 minute rate 0 bps
0 packets, 0 bytes
5 minute rate 0 bps
0 packets, 0 bytes
5 minute rate 0 bps
0 packets, 0 bytes
5 minute rate 0 bps
5 minute rate 0 bps
Queueing
The line that you have pointed refers to access-list EMAIL and the 5 minute rate are the counters for the hits the matches of access-list EMAIL. However, it should be still an average calculated in the same way, because you see that total offered rate of class Silver is 2000 bps exactly the same number under EMAIL. (it is the only ACL with traffic in this show output for class Silver)
The ouput actually provides counters per ACL not only the aggregate counters per class.
if more then an ACL has traffic in the last 5 minutes all of the counters contribute to the class counters
Hope to help
Giuseppe
