ROUTER CISCO 1905 -- PERFORMANCE
                   hello.
We are going to buy a 1905 router but we need to fix a performance table comparative between: 1905, 1921 and 1941.
We have reviewed cisco web and other link at internet but i can not find the performance in PPS and/or Mbps for the cisco router 1905.
Can some body give this value, please?
Attn.
Roger Majo
cviegas2010
8 Replies 8
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The 1905 is noted as supporting up to 10 Mbps concurrent services, while the 1921 and 1941 have WAN bandwidth recommendations of 15 and 25 Mbps, respectively.
Dear Joseph,
Thanks for your answer.
But I have found performance specification for 1941 router as is showed:
fast/cef switching: 299,000 (Mbps) and 153.08 (pps)
Do you have a 1905 performance metric in Mbps and pps?.
Thanking you in advance.
attn.
Roger Majo
Disclaimer
Posting
Sorry, only thing I found for a 1905's performance was I've already noted.
Hi, i just tested few weeks ago a cisco1905 with a JDSU generator equipment and i got 236kpps full duplex ( 472kpps half-duplex ) with 64 bytes packets size. i have not found the official value on cisco web yet.
Disclaimer
Posting
Interesting obtaining 472 Kpps for a 1905, as the 2921 is rated at 480 Kpps.
You were able, then, to push > 100 Mbps (duplex) before maxing the CPU and seeing drops?
Hi, i think the value given for cisco2921 as 480kpps is based on a bidirectional traffic test. I mean, 480 kpps in and 480 kpps out, resulting almost in 1Giga pps. I am not sure. I have been testing diferent equipments in that way and the values for me are coherent...make sense.
cviegas2010
Roger,
Read this document, it might help you.
http://www.cisco.com/web/BR/produtos/PDF/isr_g2_partner_performance_pt_BR.pdf
Cristiano Viegas
Hi Viegas,
can you mail me below document in English language.
Pls. mail me on haris@trimax.in
Hari Singh
