QoS questions and challenges
Steven Williams
Level 4
Level 4
I have a 2921 router that is connected to ISP. It has two sub-interfaces. One that directs traffic to the internet and the other one that forces traffic to the provider MPLS. I need to carve this up. Its a 100mbps pipe and need to cut it in half and dedicated 50mbps to the MPLS and 50mbps to the internet. So I assume I going to use the shaping feature to accomplish this. Once that is complete I need to create some rules that prioritize the traffic for the MPLS pipe. I am not very familiar with QoS, on a WAN routing basis. Switching only for phones.
would I apply the shaping at the physical interface or the sub interfaces? I am really looking for a way to start this and understand this.
I have the config guide for 15.4 but its a bit confusing and there is a lot of info to take in.
Thanks.
23 Replies 23
That's not the policy I posted.  I'm unsure your policy would be accepted under a subinterface.
Again, did you try what I posted?
Your code sample does not work. Service-policy is not a valid command in global config.
ChangingTheName(config)#service-policy Sample
% Invalid input detected at '^' marker.
ChangingTheName(config)#class class-default
ChangingTheName(config)#fair-queue
ChangingTheName(config)#service-policy Shape50Mclass
ChangingTheName(config)#class-default
ChangingTheName(config)#shape average 50000000
ChangingTheName(config)#interface g0.1
ChangingTheName(config-subif)#desc to Internet
ChangingTheName(config-subif)#service-policy output Shape50M
% policy map Shape50M not configured
ChangingTheName(config-subif)#interface g0.2
ChangingTheName(config-subif)#desc to MPLS
*Jun 23 14:50:42.371: %LINEPROTO-5-UPDOWN: Line protocol on Interface GMPLS0, changed state to up
Duh - slap side of my head - sorry.
Seeing your output, very helpful!
I've edited my original post.  Try it again.
This is what I see now.
hangingTheName#show policy-map interface fa0/0.3086
 FastEthernet0/0.3086
  Service-policy output: Shape50M
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
      shape (average) cir 50000000, bc 200000, be 200000
      target shape rate 50000000
ChangingTheName#
Ah, that's looks better.  Did this also have a child policy?
Where I used Sample, you should be able to use your MPLS policy.
This is what I have now. So the way I understand this parent/child thing is that everything will hit the class-default and be shaped to 50mbps, then it will look at the child policies and see if it matches any of those. So if the traffic is voice (RTP) and goes out the interface it will say ok, you belong to class-default (I am not sure what its being matched on for this though?) So now that you belong to class-default you will shape to 50mbps...now you are RTP so you fall into the voice class which says you are limited to 25 percent at a priority level of the 50mbps?
class-map match-any MPLS_VOICE_CHILD
match protocol rtp
match protocol rtsp
match protocol sip
match protocol skinny
match protocol h323
class-map match-any MPLS_REPLICATION_CHILD
match access-group name MPLS_REPLICATION_ACL
class-map match-any MPLS_STND_TRAFFIC_CHILD
match access-group name MPLS_STND_TRAFFIC_ACL
policy-map MPLS_QUEUEING_CHILD
class MPLS_VOICE_CHILD
priority percent 25
class MPLS_REPLICATION_CHILD
bandwidth percent 25
class MPLS_STND_TRAFFIC_CHILD
bandwidth percent 45
class class-default
policy-map MPLS_POLICYMAP_PARENT
class class-default
service-policy MPLS_QUEUEING_CHILD
ip access-list extended MPLS_REPLICATION_ACL
permit ip any host 192.168.2.13
ip access-list extended MPLS_STND_TRAFFIC_ACL
permit ip any 192.168.2.0 0.0.0.255
permit ip any 192.168.8.0 0.0.0.255
permit ip any 192.168.14.0 0.0.0.255
interface FastEthernet0/0.3086
description MESH VPN
bandwidth 50000
encapsulation dot1Q 3086
ip vrf forwarding mpls
ip address 1.1.1.1 255.255.255.252
service-policy output MPLS_POLICYMAP_PARENT
ChangingTheName#show policy-map interface fa0/0.3086
  Service-policy output: MPLS_POLICYMAP_PARENT
      0 packets, 0 bytes
      Match: any
      Queueing
      Service-policy : MPLS_QUEUEING_CHILD
        queue stats for all priority classes:
        Class-map: MPLS_VOICE_CHILD (match-any)
          0 packets, 0 bytes
          Match: protocol rtp
            0 packets, 0 bytes
            5 minute rate 0 bps
          Match: protocol rtsp
            0 packets, 0 bytes
            5 minute rate 0 bps
          Match: protocol sip
            0 packets, 0 bytes
            5 minute rate 0 bps
          Match: protocol skinny
            0 packets, 0 bytes
            5 minute rate 0 bps
          Match: protocol h323
            0 packets, 0 bytes
            5 minute rate 0 bps
          Priority: 25% (12500 kbps), burst bytes 312500, b/w exceed drops: 0
        Class-map: MPLS_REPLICATION_CHILD (match-any)
          0 packets, 0 bytes
          Match: access-group name MPLS_REPLICATION_ACL
            0 packets, 0 bytes
            5 minute rate 0 bps
          Queueing
          bandwidth 25% (12500 kbps)
        Class-map: MPLS_STND_TRAFFIC_CHILD (match-any)
          0 packets, 0 bytes
          Match: access-group name MPLS_STND_TRAFFIC_ACL
            0 packets, 0 bytes
            5 minute rate 0 bps
          Queueing
          bandwidth 45% (22500 kbps)
          0 packets, 0 bytes
          Match: any
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Yep, for someone who doesn't understand, you've pretty much have it fully described.
All traffic going out the subinterface will match against the parent policy's class-default.  All the class does, is shape the traffic to 50 Mbps.  Traffic that is queued by the class-default shaper, is handled by the child policy defined to class-default.   Your VoIP is LLQ'ed (i.e. it's always dequeued first), but it's also further rate limited to 25% of the 50 Mbps.
So now let the plot thicken a bit....Lets say my MPLS provider only supports 4 levels.
DSCP EF
DSCP AF31
DSCP AF11
DSCP 0
So voice is good since its matching on EF and should be tagged EF within my network.
But what about my class-maps that are matching on an ACL, so I need to mark this as they go out to one of these 4 that that the ISP is supporting?
Disclaimer
Posting
Yes, although it might be difficult to grasp, you can also have more than four classes.  If you do, you would have multiple classes remark to the same MPLS supported marking.
Your child policy allows you to manage your shaper's congestion however you would like.  The MPLS markings are used to manage congestion within the MPLS WAN cloud (especially cloud egress).  Often they are congruent, but they don't have to be.
PS:
You can also just have all traffic, using a class, be (re)marked.
