QoS sanity check
a.brazendale
Good Day,
I'm updating a QoS policy for a bunch of tunnel interfaces that we run over our WAN service. Each tunnel connects to a remote site which has a 5M internet service. Below is what I have as a standard policy that I apply facing the site (Download) on our core router. It's purpose is to accomplish:
1) LLQ for voice traffic
2) somewhat protect (minimum bandwidth during congestion) Collaboration Meetings, Control traffic and Business traffic, which is identified by an ACL and qos markings
3) everything else goes in class class-default
config:
policy-map std_child
 class Collab_Voice
  priority 1000
 class Collab_Cntrl
  bandwidth percent 4
  queue-limit 256 packets
 class Collab_Meetings
  bandwidth percent 50
 class Business
  bandwidth percent 18
 class class-default
  fair-queue
  random-detect
policy-map std_parent
 class class-default
  shape average 4500000
  service-policy std_child
I shape to 4.5M to allow for overhead and to ensure I don't hit the strict 5M policer the local ISPs have inplace. 1) does this seem like a valid policy (any adjustments?) and 2) running a speedtest from a remote site as a test, I noticed that traffic in the Business class was getting someone 'starved' even though the speedtest traffic is in the class class-default. there was no evidence of drops on increasing Q counters in the Business class during the test. I understand that other than the priority class, the bandwidth specified is not reserved, it is just the minimum available during congestion (caused by hitting the shaper).. my confusion lies within the area of, outside of the LLQ, during congestion, how are the other Collab and Business classes serviced when something appears in the default class that wants all of the bandwidth and business traffic is present? are the classes that are specified serviced first from top to bottom?
thanks,
Al
the class maps are processed top down, so whatever shows up at the top when you issue the command 'show policy-map std_parent' gets processed first. Can you post the output of that command ?
  Policy Map std_parent
    Class class-default
      Average Rate Traffic Shaping
      cir 4500000 (bps)
Output of 'show policy_map std_child';
 Policy Map std_child
    Class Collab-Voice
      priority 1000 (kbps)
    Class Collab_Cntrl
      bandwidth 4 (%)
    Class Collab_Meetings
      bandwidth 50 (%)
    Class Business
      bandwidth 18 (%)
    Class class-default
      fair-queue
       packet-based wred, exponential weight 9
      class    min-threshold    max-threshold    mark-probablity
      0       -                -                1/10
      1       -                -                1/10
      2       -                -                1/10
      3       -                -                1/10
      4       -                -                1/10
      5       -                -                1/10
      6       -                -                1/10
      7       -                -                1/10
