QoS under Subinterface
eng-sweity
        can you help me to create Qos under subinterfaces ?
    i have creat QoS on serial interface to use 50 % of bandwidth for data and 50 % of bandwidth for ip camera's and it is working well.
  but i ned to make this QoS on subinterfaces because i have 2 link , and i tried to make it on the same method as i did it on serial link but it didn't work !!
   so i need help please
6 Replies 6
John Blakley
Can you post what you have already? What's not working and are you trying to do 50% data/50% bandwidth on the subinterface?
HTH, John *** Please rate all useful posts ***
        the below configuration is working well
      class-map match-any NOT-VIDEO
match access-group 101
policy-map voice-data-50Percent
class NOT-VIDEO
  priority percent 50
class class-default
  fair-queue
interface Serial0/1/0
service-policy output voice-data-50Percent
What happens when you try to apply it? What is access-list 101?
        Extended IP access list 101
    10 deny ip host X.X.X.X any (it's for camre DVR )
    20 permit ip any any
when i apply this configuratio on Serial port it's working well
but when i am trying to apply this configuration on sub interface like
interface FastEthernet0/0.1
interface FastEthernet0/0.2
the link become very slow with high delay and some time i recived request time out
so can you give me the best cenario to solve the problem
Is fa0/0.1 or fa0/0.2 on your lan side or wan side? What direction are you putting it on the subinterface? Can you post your interface configs?
no ip address
duplex auto
speed auto
from lan to wan side
