qos verification into carrier network
kst.amand
We classify / mark traffic inbound on LAN interface and shape / queue on outbound interface in a DMVPN / GETVPN environment. Our understanding is that with classification and marking on LAN interface, DSCP / TOS bits are preserved (copied to IP Header during IPSEC encryption)on Tunnel interface. Therefore, original DSCP settings would be preserved and visible into carrier network.
Questions;
* is our understanding on preserved DSCP values correct?
* how could we verify / view, from the router itself, the DSCP are exiting the interface to the carrier
Thank you
kst.amand
Point of clarification, our outbound policy map (shape / queue) is on the WAN's physical interface.
Will the original DSCP values marked on the LAN side interface be preserved / visible as the traffic leaves the tunnel (encrypted) and goes out WAN interface?
Joseph W. Doherty
"is our understanding on preserved DSCP values correct? "
My understanding is the same for single GRE/IPSec VPN. Not 100% positive about DMVPN(mGRE) and/or GETVPN, but I think it's also true for those too.
"how could we verify / view, from the router itself, the DSCP are exiting the interface to the carrier "
What might verify the above,
1) insure outbound policy isn't remarking
2) insure outbound policy is applied to VPN's physical egress interface
3) insure pre-classify is off and/or match against a protocol that's being used (should fail)
4) examine any stats that count against DSCP markings (e.g. class match stats, DSCP WRED stats)
