QoS Voice value question
chris_tan
Hi all,
I would like to know how much Voice bandwidth are assigned in my router.
Following are the partial command from router.
Router A
policy-map MAP
class voice
    priority 200
interface Serial0/0/0.1 point-to-point
bandwidth 1024
frame-relay interface-dlci 130 IETF
class 2048Kport/1024Kcir
map-class frame-relay 2048Kport/1024Kcir
frame-relay cir 1638000
frame-relay bc 16380
frame-relay mincir 819000
service-policy output MAP
Router B
policy-map MAP
class realtime
  priority percent 5
  set ip dscp ef
interface ATM0/0/0.777 point-to-point
bandwidth 2048
pvc 1/777
  vbr-nrt 1919 1900 32
  tx-ring-limit 3
Question:
1. Does it mean the router A has 200kbps assigned for voice traffic ?
2. Does it mean the router B has 102.4kbps (5% of 2Mbps) banwidth assigned for voice traffic ?
Appreciate your comments and advice.
Thanks.
Christopher
cadet alain
1)  class voice
    priority 200
yes voice traffic will get 200 kbps when there is congestion and no more
2) No it means it will have min bw of 5 % of available bandwidth which is by default 75% of bw configured on interface
so you will get (0.75*2048)*0.05 =76.8 kbps when ther is congestion.
Regards.
Alain.
