QOS with point to multipoint bridged connections?
Patrick Beaven
Ive got two customers that are getting a providers XLAN product that is essentially a point to mulitpoint layer2 bridge.
In the early days Frame-relay used a similiar type of setup and used fram-relay class maps to solve the issues.
How can I setup QOS for one site with 25Mbps while all the other sites have 5Mbps.
I thought I could use a type of layered QOS with the PARENT service policy shaping based on destination class-maps.
then iserting a service-policy inside it. I've tried and I'm getting "Class X requested Bandwidth 300kbps , available only 100kbps"
so apparently this is not the way to solve this problem. I want to be able to average 5Mbps to each branch and also provide a priority class and business essential class. Any Ideas?
6 Replies 6
Marwan ALshawi
What you can do if it's just one interface
Create a parent policy to shape the interface to 25m using class-default
Then create acl per remote site that had the source as the hub network and destination a remote site
Then create a class map per site using the relevant acl created above
Then add new policy map that uses the classes above and user each class police the traffic to 5m
Apply this policy under the parent policy
And then apply the parent policy to the interface in the outbound direction
Hope this help
If helpful rate
This is exactly what I did but when I do I get the "class X requested Bandwidth 300Kbps available only 100kbps"
It references the VOICE class I have setup. So i tried using priority percent unstead of a defined amount and I dont get the error but I suspect its not going to work as expected. Do you know if its possible to have three tiers of embeded QOS on a router? I set the parent policy to shape each site at 5Mbps then used the second level to setup a priority for voice and set percentage for Business applications.
Can you post your config here
here is the config:
class-map match-all AVID
match access-group name ACL-AVID
class-map match-all all-shape
match access-group name ACL-ALL
class-map match-all DEB-NET
match access-group name DEB-NET
class-map match-all TWO-NET
match access-group name TWO-NET
class-map match-all WEB
match access-group name ACL-WEB
policy-map QOS
class AVID
  priority percent 9
  set dscp ef
class WEB
  bandwidth remaining percent 60
  set dscp 41
class class-default
  set dscp default
policy-map alltraffic
class TWO-NET
  shape average 4440000
class DEB-NET
  shape average 100000
  service-policy QOS
and where you getting the problem ?
my suggestion was to police the traffic per class/site
example
lets say the hub site IP range is 10.1.1.0/24 link 25M
remote site1 192.168.1.0/24 links 5M
remote site2 192.168.2.0/24 5M
on the hub site
access-list 101 permit ip any 192.168.1.0 0.0.0.255
access-list 102 permit ip any 192.168.2.0 0.0.0.255
class-map site1
match access-group 101
class-map site2
match access-group 102
policy-map PerSiteQoS
class site1
  police cir 5000000
class site2
police cir 5000000
policy-map SHAPE
class class-default
shape avvarge 25000000
service-poicy PerSiteQoS
this way you will shape the interface to 25M and traffic going to each remote site to 5M per site !
not sure if this is what you looking for
I see but it doesnt allow for setting up of Class Based traffic shaping for voice and business apps.
The problem with my setup is where you see the 9% for voice. I initially set it up for 310Kbps and thats when it failed with the error i displayed in the first post of the thread. Any suggestions on either a work around or do you recommend not using a specific amount with priority queueing?
