Query on debug ip packet detail ouput
While  I am debuging ICMP traffic originated from a router ( Debug ip packet  details) it is showing packets routed via FIB and reply is showing as  routed via RIB .is it means ICMP packet originating from the router is  CEF switched ? if it does then whether the CEF switched packet will show  in the debug  output ?.Documents showing that only process switched  packet can be debugged .
one more doubt regarding the routing process
documents stating that the routing process is actually consist of three processes 1.routing 2.switching 3.encapsulation
so  regardless of every switching methods (Process ,Fast or CEF ) router is  doing routing table lookup in the first process (Routing) ?
thanks
Arun Mohan
cadet alain
Process switching : route lookup for every packet
Fast switching: route lookup for first packet then use the fast switching cache for next packets going to same destination
CEF: the FIB is prebuilt from the RIB and the router uses FIB to forward packet
Regards.
Alain
