Question about IBGP, OSPF relationship
west33637
This is a question of how IBGP operates with OSPF.
Firslty, synchronization has been disabled.
My understanding is that IBGP will check its BGP table for best next-hop to its intended destination. Then after that best next-hop is determined, BGP will then tell OSPF here is my best next hop. Get me there! Thats when the recursive routing now takes place. Is this correct?
Please no guess work. Answer, only if you are sure. Thanks,
yes, your understanding or recursion is correct
Hope to help
Giuseppe
Giuseppe Larosa
Hello west33637,
so it is in provider networks for successful forwarding one of the following conditions has to be met:
a) or iBGP is enabled everywhere using  route reflector servers and/or BGP confederations to avoid internal black holes
b) or MPLS is enabled, an LSP exists with destination = BGP next-hop, in this case a BGP free core can exist and internal MPLS routers don't need to know how to route the packet just how to switch the MPLS frame that carries the packet inside itself.
in several providers both conditions are true if a BGP free core is not  present.
with MPLS two levels of recursion can happen:
BGP choices the BGP next-hop
the BGP next-hop is used to check IGP routing table and MPLS forwarding table
traffic is sent over an LSP with destination = BGP next hop
the IP packet is encapsulated in an MPLS frame  with label value = the value expected by next router in the path to destination
Hope to help
Giuseppe
Hello giuslar. Thx for the detailed response. Taking MPLS and route reflectors/confeds out of the equation, can I assume from your response that my initial assumption of the workings between IBGP and OSPF are correct? Thanks,
Hope to help
Giuseppe
