06-21-2011 12:25 PM - edited 03-04-2019 12:46 PM
hi i have the logging showing ;
Jun 16 15:22:50: %CIRRUS-5-LINEFLAP: Unit 11 excessive modem control changes.
how can i figure out what is the fisical interface flaping on the log from the show idc output ?
#show idb
Maximum number of Software IDBs 1400. In use 96.
HWIDBs SWIDBs
Active 50 61
Inactive 35 35
Total IDBs 85 96
Size each (bytes) 2912 1280
Total bytes 247520 122880
Type SIdx Idx St,O,Sh Interface Name (subblocks)
H 1 2 U,U,R FastEthernet0/0 (HW IFINDEX(10001), HW SB CDP(6), HSRP(7), MAC ADDR(2), Ether(1))
H 2 3 U,U,R FastEthernet0/1 (HW IFINDEX(10001), HW SB CDP(6), HSRP(7), HW IP ACCESS(5), DOT1Q(8), MAC ADDR(2), Ether(1))
H 3 4 A,D,R Serial1/0 (HW IFINDEX(10001), HW SB CDP(6), HW IP ACCESS(5), Serial(3))
H 4 5 A,D,R Serial1/1 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 5 6 A,D,R Serial1/2 (HW IFINDEX(10001), HW SB CDP(6), HW IP ACCESS(5), Serial(3))
H 6 7 A,D,R Serial1/3 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 7 8 A,D,R Serial1/4 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 8 9 A,D,R Serial1/5 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 9 10 A,D,R Serial1/6 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 10 11 A,D,R Serial1/7 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 11 12 A,D,R Serial2/0 (HW IFINDEX(10001), HW SB CDP(6), HW IP ACCESS(5), Serial(3))
H 12 13 A,D,R Serial2/1 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 13 14 U,A,R Serial2/2 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 14 15 U,D,R Serial2/3 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 15 16 U,U,R Serial2/4 (HW IFINDEX(10001), Frame relay(9), Serial(3))
H 16 17 A,D,R Serial2/5 (HW IFINDEX(10001), HW SB CDP(6), HW IP ACCESS(5), Serial(3))
H 17 18 A,D,R Serial2/6 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 18 19 U,U,R Serial2/7 (HW IFINDEX(10001), HW SB CDP(6), HW IP ACCESS(5), Serial(3))
H 19 20 U,U,R Serial3/0 (HW IFINDEX(10001), HW SB CDP(6), HW IP ACCESS(5), Serial(3))
H 20 21 U,A,R Serial3/1 (HW IFINDEX(10001), HW IP ACCESS(5), HW SB CDP(6), Frame relay(9), Serial(3))
H 21 22 U,U,R Serial3/2 (HW IFINDEX(10001), HW SB CDP(6), HW IP ACCESS(5), Serial(3))
H 22 23 U,U,R Serial3/3 (HW IFINDEX(10001), HW SB CDP(6), Serial(3))
H 23 24 A,D,R Serial4/0 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 24 25 A,D,R Serial4/1 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 25 26 U,D,R Serial4/2 (HW IP ACCESS(5), HW IFINDEX(10001), HW SB CDP(6), Serial(3))
H 26 27 U,U,R Serial4/3 (HW IFINDEX(10001), HW IP ACCESS(5), HW SB CDP(6), Frame relay(9), Serial(3))
H 27 28 U,D,R Serial4/4 (HW IP ACCESS(5), HW SB CDP(6), Frame relay(9), HW IFINDEX(10001), Serial(3))
H 28 29 A,D,R Serial4/5 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 29 30 A,D,R Serial4/6 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 30 31 U,U,R Serial4/7 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 31 32 U,U,R Serial5/0 (HW IFINDEX(10001), HW SB CDP(6), Serial(3))
H 32 33 U,U,R Serial5/1 (HW IFINDEX(10001), HW SB CDP(6), HW IP ACCESS(5), Serial(3))
H 33 34 U,U,R Serial5/2 (HW IFINDEX(10001), HW SB CDP(6), HW IP ACCESS(5), Serial(3))
H 34 35 U,U,R Serial5/3 (HW IFINDEX(10001), HW SB CDP(6), HW IP ACCESS(5), Serial(3))
H 35 36 A,D,R Serial6/0 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 36 37 A,D,R Serial6/1 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 37 38 A,D,R Serial6/2 (HW IFINDEX(10001), HW SB CDP(6), HW IP ACCESS(5), Serial(3))
H 38 39 A,D,R Serial6/3 (HW IFINDEX(10001), HW SB CDP(6), Serial(3))
H 39 40 U,U,R Serial6/4 (HW IFINDEX(10001), Frame relay(9), HW IP ACCESS(5), Serial(3))
H 40 41 U,U,R Serial6/5 (HW IFINDEX(10001), HW SB CDP(6), HW IP ACCESS(5), Serial(3))
H 41 42 U,U,R Serial6/6 (HW IFINDEX(10001), HW SB CDP(6), HW IP ACCESS(5), Serial(3))
H 42 43 A,D,R Serial6/7 (HW IFINDEX(10001), HW IP ACCESS(5), HW SB CDP(6), Frame relay(9), Serial(3))
H 43 80 U,D,R NVI0
H 44 79 A,D,R Multilink1 (HW IFINDEX(10001), HW SB CDP(6), HW IP ACCESS(5), Serial(3))
H 45 81 A,D,R Multilink2 (HW IFINDEX(10001), HW SB CDP(6), Serial(3))
H 46 82 U,D,R Multilink3 (HW IFINDEX(10001), HW SB CDP(6), HW IP ACCESS(5), Serial(3))
H 47 78 U,D,R Loopback0 (HW IFINDEX(10001))
H 48 84 U,D,R Loopback1 (HW IFINDEX(10001))
H 49 83 A,U,R Loopback15 (HW IFINDEX(10001))
H 50 1 U,D,R VoIP-Null0 MZ-EE-RT-3B#show idb
HWIDBs SWIDBs
Active 50 61
Inactive 35 35
Total IDBs 85 96
H 43 80 U,D,R NVI0
Solved! Go to Solution.
06-21-2011 01:59 PM
Please try to have a look at one of the following commands:
Perhaps one of them will either allow you to see or specify the unit ID, or will allow you to see the statistics of modem control changes which should be inordinately high compared to other ports.
Best regards,
Peter
06-21-2011 12:59 PM
I am not sure if that can be deduced from the show idb output. Is that the only logging message displayed? Can you perhaps have a look into show interfaces or show line output and search for excessive information about link up/down transitions?
Best regards,
Peter
06-21-2011 01:39 PM
Hi peter,
With this log message there is some way to figure out what is the physical interface ?
Thank you.
06-21-2011 01:59 PM
Best regards,
Peter
06-21-2011 02:43 PM
I think we got a winner.
This is regarding that modem log right ? "%CIRRUS-5-LINEFLAP: Unit 11" -> "modem 1613"
CD2430 Slot 2, Port 3, Controller 0, Channel 3, Revision 19
Channel mode is synchronous serial
idb 0x64A16CD8, buffer size 1524, V.35 DTE cable
Global registers
rpilr 0x2, rir 0x3, risr 0x0, rfoc 0x0, rdr 0x0
tpilr 0x1, tir 0x2, tisr 0x68, tftc 0x0, tdr 0x1
mpilr 0x3, mir 0x3, misr 0x20
bercnt 0xFF, stk 0x0
Per-channel registers for channel 3
Option registers
0x02 0x00 0x42 0xE7 0xE0 0x00 0x00
Command and status registers
cmr 0xC0, ccr 0x00, csr 0xCC, msvr-rts 0xF1, msvr-dtr 0xF1
Clock option registers
rcor 0x06, rbpr 0x01, tcor 0xC8, tbpr 0x01
Interrupt registers
ier 0x89, livr 0x0C, licr 0x0C
DMA buffer status 0x0A
DMA receive registers
arbaddr 0x767A624, arbcnt 1548, arbsts 0x1
brbaddr 0x7679FA4, brbcnt 1548, brbsts 0x1
rcbaddr 0x76792B2
DMA transmit registers
atbaddr 0x7401394, atbcnt 14, atbsts 0x62
btbaddr 0x7772774, btbcnt 14, btbsts 0x62
tcbaddr 0x74013A2
Special character registers
schr1 0x00, schr2 0x00, schr3 0x00, schr4 0x00
scrl 0x0, scrh 0x0, lnxt 0xD1
Driver context information
Context structure 0x64A18FFC, Register table 0x3E000400
Serial Interface Control 5:1 Register (0x3E00080E) is 0x0
Adaptor Flags 0x0
Serial Modem Control Register (0x3E000810) is 0x18
Receive static buffer 0x64A1A2A0
Receive particle buffers 0x64A19740, 0x64A19700
Transmit DMA buffers 0x0, 0x0, 0x0, 0x0
Transmit packet with particles 0x0, first word is 0x0
Interrupt rates (per second) transmit 0, receive 0, modem 1613
True fast-switched packets 0
Semi fast-switched packets 0
Transmitter hang count 0
Residual indication count 0
Bus error count 0
Aborted short frames count 29
CRC short frames count 54
Tx DMA low threshold count 1
Error counters
CTS deassertion failures 0
Nested interrupt errors transmit 0, receive 0, modem 0
Global registers
Option registers
Interrupt registers
rcbaddr 0x76792B2
tcbaddr 0x74013A2
Adaptor Flags 0x0
Bus error count 0
Error counters
also i got the show diag output. and with the math matches the number.
Please let me know if this is correct.
Slot 1:
Sync/Async Port adapter, 8 ports
Port adapter is analyzed
Slot 2:
Port adapter insertion time 1y14w ago
EEPROM contents at hardware discovery:
Hardware revision 1.0 Board revision J0
Serial number 25149990 Part number 800-01225-02
FRU Part Number NM-8A/S=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x00: 01 25 01 00 01 7F C2 26 50 04 C9 02 00 00 00 00
0x10: 98 00 00 00 01 01 26 17 FF FF FF FF FF FF FF FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FFSlot 1:
Thank you very much.
