Question about Static nat and ACL's
jmartinez
Beginner
Beginner
Hello to all,
I want to map port 3389 from my WAN interface to a LAN host, but i only want that a unique IP can connect with this device; this is the configuration that i was made:
imagine that 2.2.2.2 is the public IP of the machine that i want to acces to my LAN.
the LAN IP address is 1.1.1.1 and the public IP of my LAN is  10.10.10.10. ok first i have to configure the static NAT:
ip nat inside source static tcp 1.1.1.1 3389 10.10.10.10 3389 extendable
and then i have created and ACL and apply it to my WAN interface, in this case dialer 0;
access-list 101 permit tcp host 2,2,2,2 eq 3389 any eq 3389
access-list 101 deny   tcp any eq 3389 any eq 3389
access-list 101 permit ip any any
once the access-list is generated i have applied it in, dialer 0 interface IN:
ip access-group 101 in
but i still can connect to my LAN from any IP what's wrong?
thanks in advance
regards
Jennifer Halim
The ACL deny statement should just say the following:
access-list 101 deny   tcp any any eq 3389
Because the source port will never be 3389, therefore, you do not need to specify the source port of 3389 in the deny statement.
Same for the first line of ACL, it should just be as follows:
access-list 101 permit tcp host 2.2.2.2 any eq 3389
Overall, the ACL should say as follows:
