Question_As_Path_Prepend
Vinayaka Raman
All the branch end MPLS routers injects sites BGP prefix in to the service provider’s cloud by forming EBGP neighbhorship with PE.
In my scenario, I need to inject same prefix from two of the branches so that the actual MPLS route is always better than the other backup route.
This back route is static to BGP redistributed route. While redistributing I want to prepend AS so that it becomes the worst route. Right now, MED is configured and it is not working as expected because the service provider is hoping through Multiple AS for the actual MPLS route.
Router bgp 65000
Redistribute static route-map prepend As
Route-map permit 10
Set As path 65000 65000
This isn’t working .  Do you have some suggestion ?
I will post the actual error message in a while.
Regards Vinayak
28 Replies 28
cadet alain
you're missing the route-map name. It should be:
Route-map permit prepend As 10
Regards.
Alain.
Router bgp 65000
Ip route X.X.X.X Y.Y.Y.Y next hop 150
redistribute static route-map Prepend_AS
Route-map Prepend_AS 10
sorry for the typo...
I forget the exact error message. While I issue this redistribute command It throws me an error like this is not possibl
I will post the error message soon.
Is this configuration correct ?
My intention is to prepend the AS after redistributing from static to bgp and then advertise to eBGP peer.
Regards Vinayak
Hi Raman
If we need to prepend the AS-Path which is being advertised to other BGP Peers the best way is t first redistribute the Static ROutes into BGP Process and then apply an outbound route-map on per neighbiur basis under BGP config which prepends the AS. I wonder if the redistribution of Static ROutes into BGP and same time prepending will be allowed or not.
The solution for prepending would be as follows:
route bgp 65000
neighbour x.x.x.x route-map Prepend_AS out
redistribute static
route-map Prepend_AS permit 10
set as-path prepend 65000 65000
Hope this helps to answer your query.
Varma
the correct config should be set as-path prepend 65000 65000  but you should configure this like this:
Because AS_PATH prepending is for advertising BGP prefixes not for redistributing static routes.
I still wonder how I didn't realize it at first look.
Alain.
I wanted only the redistributed static routes to be prpended with AS..
So do you want me to create a prefix list and match under route-map..
Regards Vinayak
Forgot to mention i have 2 more major prefixes advertisde from my CE to PE, i dont want to prpend that...
only i want to prepend the static to bgp redistributed routes...
Regards Vinayak
Hi Raman
If we want to prepend only specific prefix then we need to have 2 terms in the outbound route-map:
1. Term 10 for prepending the required prefixes matched via a Prefix-List and prepend the AS-Path
2. Term 20 to allow everything else remaining un-prepended
route bgp 65000
redistribute static
match ip address prefix-list Prepend_AS
route-map Prepend_AS permit 20
ip prefix-list Prepend_AS seq 5 permit x.x.x.x/24
Varma
route bgp 65000
redistribute static
Ip route X.X.X.X/24 next hop 150
Ip route Z.Z.Z.Z/24 next hop 150
match prefix-list Static-routes
Ip prefix-list Static-routes permit  X.X.X.X/24
Ip prefix-list Static-routes permit  Z.Z.Z.Z/24
Regards Vinayak
yes you can match the prefixes with a prefix-list and prepend them.
Don't forget to add an empty  route-map permit 20 for other prefixes to be advertised.
Alain.
just review and let me know if the configuration looking good.
I had to use Clear ip bgp* for the configs to take effect immediately
Do you suggest an alternate way like
clear ip bgp * soft in
clear ip bgp * soft out
I dont think this worked when i tried for the first time
Regards Vinayak
Hi Raman
In my personal opinion we should never do a hard reset on BGP peers, the soft way which you have mentioned is the most optimal way withiut interrupting traffic flow.
Varma
Ok...got it...
Do you suggest any changes in the config i posted. ?
Regards Vinayak
Hi Raman
Yes the config logic is correct. I did not look at the syntax typo though. You can refer my sample config snapshot which I shared in earlier post and look in the below excellent cisco docs for config syntax :-)
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c95bb.shtml
Varma
Thank you Vaibhav and Alain..I will implement this and let you know how it goes
Regards Vinayak
