Question on Cisco 3945
minumathur
Can someone tell me how configure vlan tagg on routed layer 3 interface in cisco 3945 device, if someone send me configuration example that will be great.
Thank you
Josh Sprang
(vlan 2 example)
Interface g0/0.2
Encap dot1q 2
Ip add 192.168.1.1 255.255.255.0
(vlan 3)
Int g0/0.3
Encap dot1q 3
Ip add 10.1.1.1 255.255.255.0
G0/0 will tag facing the switch
For untagged
Int g0/0.1
Encap dot1q 1 native
Ip add 10.2.2.2 255.255.255.0
Thanks very much. This helped me today.
Then you should give him few stars Lolz
