dsu bandwidth setting for 10mb mpls link
Bedevere Curry
I have a question in regards to the dsu bandwidth statement.
If we are using 10mb mpls link, should we change it the dsu bandwidth statement?
nh112#sh run int se1/0
Building configuration...
interface Serial1/0
no ip address
encapsulation frame-relay IETF
load-interval 30
dsu bandwidth 44210 <<<<<<<<
service-policy input Verify_QOS_IN
service-policy output QOS_OUT
end
nh112#sh run int se1/0.100
interface Serial1/0.100 point-to-point
description ATT MPLS VPN:
bandwidth 10000 <<<<<<<<
ip address 205.27.33.55 255.255.255.252
ip flow ingress
ip flow egress
snmp trap link-status
frame-relay interface-dlci 100 IETF
end
3 Accepted Solutions
vmiller
Level 7
Level 7
My bet is that it is not a serial link connection at that line rate, and its not encapsulated frame relay either.
What details do you have from the carrier ?  They should provide you with a minimum of the physical charactaristics of the hand off.
rfalconer.sffcu
Level 3
Level 3
The bandwidth statement is used by routing protocols to make routing decisions. Having the full DS3 bandwidth on the s1/0 interface shouldn't matter in the routing calculation since the subinterface(s) is what's being used.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
No, all that corresponds to is your physical port bandwidth.  The 10 Mbps is a logical cap within your WAN provider's cloud.  For that, you can (and probably should) shape your egress to not exceed the logical cap.  (BTW using the bandwidth statement on the subinterface does not shape.  You would need to explicitly shape.  Also BTW, your provider is likely providing 10 Mbps of L2 bandwidth but I believe most Cisco shapers only account for L3.  I.e. you need to shape for somewhere in the range 8.5 to 9.5 Mbps, L3, to not overrun 10 Mbps, L2.)
6 Replies 6
vmiller
Level 7
Level 7
The circuit is up and running and we are using frame-relay encapsulation. We have it configured the same way on both ends. Just wondering if the dsu bandwidth should reflect 10mb as our mpls data rate provided by the carrier is 10mb.
rfalconer.sffcu
Level 3
Level 3
Thank you
Joseph W. Doherty
Disclaimer
Posting
Thanks Joseph. Much appreciated everyone
