Question on memory requirements on a 3640
spfister336
Level 2
Level 2
I've got a 3640 I'm trying to get a new IOS on (12.3(14)T7, IP plus). The feature navigator says it needs 96mb dram, 32mb flash, which the router has, but it crashes with an "out of memory" error every time it tries to boot. IOMem is set to 15% and whatever I do it never seems to change. It seems to be 15% by default and I've tried 'memory-size iomem 5' and 'no memory-size iomem 15', but nothing is working. What can I do?
smahbub
Level 6
Level 6
Details about the memory capacity and flash card to be used are present in the guide.
Refer the "3600 Series Memory Options and Configuration Guide" present in the following url for more information on memory usage in 3600 series routers:
http://www.cisco.com/en/US/products/hw/routers/ps274/prod_bulletin09186a0080091f70.html
