Question on overlap-IP range within organization
news2010a
Level 3
Level 3
Imagine my internal network-organization operates using IP=192.168.1.0/24.
Imagine I have a Department-in-another-corner-of-theworld using private address range 10.0.0.0/8.
Then My-Department-US has some hardcoded devices which require IP address in the range 10.0.0.0/8 in order to operate. Such devices should be placed behind a layer 3 device (router or switch) in order to contain broadcast traffics anyway.
That said, if I let this My-Department-US connect OK on 10.0.0.8/24 and I do #ip nat inside and I translate all inside local addresses on 10.0.0.8/24 using an 'inside global' 192.168.1.0/24 do you see any technical or practical issue in which I should prevent them from using such 10.0.0.0/24 behind this layer 3 device? Just because that IP address range 10.0.0.0/24 conflicts with the Department-inanother-corner-oftheworld that should not be a technical or practical issue to prevent this? Am I right?
It may or mayn't create problems and that depends on lot of factors. It's very hard to give a correct answer without knowing the whole topology and who is initiating the traffic etc. But, to be sure that you don't run into problems you would want NAT the users on both sides and ensure you have routes to get to the NAT IP range from the remote routers.
Sundar
mohammedmahmoud
Level 11
Level 11
Kindly check this document:
Using NAT in Overlapping Networks
http://www.cisco.com/warp/public/556/3.html
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Sundar
hi Sundar,
how do you configure the route to point to the NATed range of IP? if I am using EIGRP, can I just add the NATed range into the EIGRP?
Thanks much,
pn
Hi Pn
Yes, that is exactly what you do. You can add a route for the Natted address range and redistribute it into EIGRP.
Jon
