10-24-2017 11:45 PM - edited 03-05-2019 09:22 AM
As per Cisco documentation at
"You can create Frame Relay connections using one of the following hardware configurations:
My question is on point number 1.
Here is the link i am referring to.
10-25-2017 12:35 AM
they probably refer to routers with DSU/CSU WAN Interface Cards, which means the DSU/CSU is integrated into the router rather than having to connect to an external CSU/DSU device. Check the link below for reference.
10-25-2017 04:38 AM
Thank you. It make sense now.
I have one more question though. Please have a look at the link below.
https://www.cisco.com/c/en/us/support/docs/wan/frame-relay/14193-frbacktoback.html
It shows how to connect 2 routers back to back to simulate a Frame relay. They do it by configuring one Router as DTE and another one as DSU. To configure the Router as DSU, they will set the clock. If a router does not have a Serial interface it can be added as an additional module. Once that is done a Serial cable is used to connect 2 routers and simulate a Frame Relay by setting Frame Relay as encapsulation protocol on the Routers.
I am very new to this field and trying to learn how these things work in the field.
10-25-2017 06:02 AM
