Question on the display of 'show logg'
bulgogi09
Can someone please explain to me what the '.' in front of these messages mean?
May 22 10:17:34.956: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10205: Neighbor 10.205.3.138 (Tunnel0) is up: new adjacency
May 22 10:17:41.776: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10205: Neighbor 10.205.6.99 (Tunnel0) is up: new adjacency
May 22 10:18:54.468: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10205: Neighbor 10.205.3.138 (Tunnel0) is down: retry limit exceeded
May 22 10:18:54.640: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10205: Neighbor 10.205.3.138 (Tunnel0) is up: new adjacency
May 22 10:20:14.156: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10205: Neighbor 10.205.3.138 (Tunnel0) is down: retry limit exceeded
May 22 10:20:17.060: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10205: Neighbor 10.205.3.138 (Tunnel0) is up: new adjacency
.May 22 10:21:36.572: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10205: Neighbor 10.205.3.138 (Tunnel0) is down: retry limit exceeded
.May 22 10:21:40.360: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10205: Neighbor 10.205.3.138 (Tunnel0) is up: new adjacency
.May 22 10:22:03.664: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10205: Neighbor 10.205.6.190 (Tunnel0) is up: new adjacency
.May 22 10:22:07.792: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10205: Neighbor 10.205.3.47 (Tunnel0) is down: holding time expired
.May 22 10:22:10.352: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10205: Neighbor 10.205.6.131 (Tunnel0) is down: holding time expired
.May 22 10:22:36.976: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10205: Neighbor 10.205.6.131 (Tunnel0) is up: new adjacency
.May 22 10:22:37.072: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10205: Neighbor 10.205.3.47 (Tunnel0) is up: new adjacency
.May 22 10:23:00.048: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10205: Neighbor 10.205.3.138 (Tunnel0) is down: retry limit exceeded
.May 22 10:23:03.388: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10205: Neighbor 10.205.3.138 (Tunnel0) is up: new adjacency
May 22 10:24:06.893: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10206: Neighbor 10.206.0.87 (Tunnel1) is down: Interface Goodbye received
May 2
Thank you.
John
The log entries with a "." preceeding the date is an indicator that while the router believes that it knows what time it is, that the time is not authoritative (and potentially not accurate). My guess is that this router is running NTP to learn time and while these messages about EIGRP neighbors going down and coming up that the router lost (temporarily) its connection to the NTP server. When the log messages start having the date with no "." preceeding it is a sign that the router has re-established its connection to the NTP server and that the time stamp is now authoritative (and accurate).
Rick
Rick
mike-greene
Level 4
Level 4
If your referring to the 956 in this number "10:17:34.956", I believe thats microseconds.
John
Rick
Rick
