Can someone help me check that the following hardware will run on my 7604 with sup720 and sip 400.
I need to run s72033-ipservices_wan-mz.122-18.SXF2
will the following SPA card work ?
SPA-1XOC12-POS
I am concerned that although I think the IOS release is high enough I can't confirm that the supervisor firmware is compatable
many thanks for any pointers in the right direction,
Will
incase i've missed anything obvious, here's a sh hard
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICES_WAN-M), Version 12.2(18)SXF2,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Thu 19-Jan-06 05:17 by dchih
Image text-base: 0x40101040, data-base: 0x42A58000
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICES_WAN-M), Version 12.2(18)SXF2,
cpe-u-01-gsn-usdal01n uptime is 18 weeks, 4 days, 10 hours, 37 minutes
Time since cpe-u-01-gsn-usdal01n switched to active is 18 weeks, 4 days, 10 hour
s, 36 minutes
System returned to ROM by reload (SP by reload)
System restarted at 22:51:47 UTC Sat Sep 15 2007
System image file is "bootdisk:s72033-ipservices_wan-mz.122-18.SXF2.bin"
cisco CISCO7604 (R7000) processor (revision 2.0) with 983008K/65536K bytes of me
mory.
Processor board ID FOX1102023M
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
1 SIP-400 controller (4 GigabitEthernet).
1 Virtual Ethernet/IEEE 802.3 interface
6 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
