Question Regarding Object Tracking Statement "not"
dperezoquendo
I see the following configured in a device and I was wondering if I could get some insight on what exactly the following means (this is the full configuration of the track list):
track 2 list boolean or
  object 1 not
ip route 0.0.0.0 0.0.0.0 x.x.x.x track 2
The description on Cisco documentation, https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_50_se/configuration/guide/scg/sweot.pdf, doesn't make any sense to me. What is the purpose of this and what does it really do?
My understanding of what I read would mean that this default route will always be tracked down? If so, then whats the point of having it in the configuration if it will never go up?
Giuseppe Larosa
Hello dperezoquendo,
what is the object 1? what it is monitoring?
the track 2 will be TRUE / UP if the object 1 state is FALSE/down.
So a possible interpretation of the configuration is the following:
this default static route should be used only when object 1 is down, so it is actually a backup default route and not the primary route.
Be noted that object 1 must be defined in configuration or the track configuration would not be accepted.
So you should look at what object 1 is and what is its state.
The usual configuration would track the primary route and would use a floating static route as backup using a positive logic (not using not operator in boolean expression).
Hope to help
Giuseppe
Giuseppe Larosa
Hope to help
Giuseppe
Thanks for bringing that up, that was actually another question I had that I forgot to ask. What is "object #" suppose to be? I don't see anything in the configuration outlined as "object 1". Is it suppose to be track 1? If it is, then track 1 appears to be an IP SLA that will ping 8.8.4.4 every 5 seconds.
So in summary:
The default route will be utilized if track 1 fails.
I am also more akin to seeing the usual configuration as you mentioned. I found the NOT statement and the Cisco explanation confusing so I needed that clarity. Thanks for the help.
