Question
Hamza ahmed
Hi, there I have catalyst 2960 x series I want to access the internet from a home router without any Cisco
when I ping google form the switch it’s successful but on my  laptop I can’t
can someone help me with it ?
I have have  my
ISP rtr
connect to a linksys rtr than to my Cisco Switch with
sfp port g1/0/49
Hello
can you elaborate a little- do you mean ypu have a none cisco rtr attached to a cisco catalyst switch? , If so can you confirm if you have access and administrative control to this rtr?
Kind Regards
Paul
I have have  my
ISP rtr
sfp port g1/0/49
Larry Sullivan
Level 3
Level 3
Guessing your 2960 has and SVI set to get an IP via DHCP from your Linksys which the Linksys then NATs for internet access.  Is your PC getting a DHCP address from your Linksys too?
