Questions regarding ISA3000 Firewall
axel-r
I wanted to know if:
  1. Can you designate an IP address from a BVI interface as a Default Gateway to all kinds of end point devices connected to any of the interfaces belonging to the bridge group?
  2. Should it  be possible to ping that interface from the connected devices on the inside interface, wheteher bvi or not?
Sure you can use BVI IP as GW for all host in vlan bridge by this BVI.
And you can not ping it from other host in other vlan (not in same bridge) because th ftd and asa not allow ping from one interface to other' it allow ping to direct connect interface or ping pass through FW
MHM
