Queue Limit and Hold queues on Nested CBWFQ
Marc Day
I am to understand how the queue-limit is calculated on ASR Version 16.03.02
The configuration for the CBWFQ is as follows
policy-map WAN-OUT-CBWFQ-10M-EF
 class EF
  priority 10240
 class Routing
  bandwidth remaining percent 3
 class AF4
  bandwidth remaining percent 25
  random-detect dscp-based
  random-detect dscp 32 180 360
  random-detect dscp 34 180 360
  queue-limit 400 packets
 class AF3
  bandwidth remaining percent 10
  random-detect dscp 24 180 360
  random-detect dscp 26 100 200
  random-detect dscp 28 100 200
 class AF2
  random-detect dscp 18 75 150
  queue-limit 200 packets
 class class-default
  bandwidth remaining percent 52
  queue-limit 1000 packets
  fair-queue
  random-detect dscp 0 600 900
policy-map WAN-OUT-SHAPE-50M-10M-EF
 description parent policy for interface shaping
 class class-default
  shape average 47000000
   service-policy WAN-OUT-CBWFQ-10M-EF
interface GigabitEthernet0/0/2
 bandwidth 51200
 service-policy output WAN-OUT-SHAPE-50M-10M-EF
 hold-queue 2000 in
 hold-queue 2000 out
When I look at the policy output on the interface I see the default queue-limit for the parent policy is 195 packets how is this calculated please, I understand priority class defaults to 512 so I need to account for that in the configuration still, but its the parent queue-limit that I am trying to understand.  I could manually set this, but not sure what to set it to if I did that?
I have read "The router uses 50 ms of 1500-byte packets but never less than 64 packets" but I am not sure what this means?
show policy-map interface g0/0/2
  Service-policy output: WAN-OUT-SHAPE-50M-10M-EF
    Class-map: class-default (match-any)
      1466948249 packets, 518033603132 bytes
      30 second offered rate 11226000 bps, drop rate 0000 bps
      Match: any
      Queueing
      queue limit 195 packets
      (queue depth/total drops/no-buffer drops) 0/410947/0
      (pkts output/bytes output) 1466454655/517738905408
      shape (average) cir 47000000, bc 188000, be 188000
      target shape rate 47000000
      Service-policy : WAN-OUT-CBWFQ-10M-EF
        queue stats for all priority classes:
          Queueing
          queue limit 512 packets
          (queue depth/total drops/no-buffer drops) 0/0/0
          (pkts output/bytes output) 39584544/8419136844
        Class-map: EF (match-any)
          39584544 packets, 8419136844 bytes
          30 second offered rate 143000 bps, drop rate 0000 bps
          Match: ip dscp ef (46)
          Priority: 10240 kbps, burst bytes 256000, b/w exceed drops: 0
        Class-map: Routing (match-any)
          4125680 packets, 384082015 bytes
          30 second offered rate 11000 bps, drop rate 0000 bps
          Match: ip dscp cs6 (48)
          Match: ip dscp cs7 (56)
          Queueing
          (pkts output/bytes output) 4052728/373880995
          bandwidth remaining 3%
        Class-map: AF4 (match-any)
          85805928 packets, 80746182000 bytes
          30 second offered rate 4018000 bps, drop rate 0000 bps
          Match: ip dscp cs4 (32) af41 (34)
          Queueing
          queue limit 400 packets
          (pkts output/bytes output) 85805928/80746182000
          bandwidth remaining 25%
            Exp-weight-constant: 4 (1/16)
            Mean queue depth: 1 packets
            dscp       Transmitted         Random drop      Tail drop          Minimum        Maximum     Mark
                    pkts/bytes            pkts/bytes       pkts/bytes          thresh         thresh     prob
            cs4     77142216/74622342688      0/0              0/0                180           360  1/10
            af41     8663712/6123839312      0/0              0/0                180           360  1/10
        Class-map: AF3 (match-any)
          1384871 packets, 548506638 bytes
          30 second offered rate 2000 bps, drop rate 0000 bps
          Match: ip dscp af31 (26) af32 (28)
          Queueing
          (queue depth/total drops/no-buffer drops) 0/89/0
          (pkts output/bytes output) 1384782/548375443
          bandwidth remaining 10%
            cs3            0/0               0/0              0/0                180           360  1/10
            af31     1384782/548375443      37/53901         52/77294            100           200  1/10
            af32           0/0               0/0              0/0                100           200  1/10
        Class-map: AF2 (match-any)
          0 packets, 0 bytes
          30 second offered rate 0000 bps, drop rate 0000 bps
          Match: ip dscp af21 (18)
          Queueing
          queue limit 200 packets
          (pkts output/bytes output) 0/0
            Mean queue depth: 0 packets
            af21           0/0               0/0              0/0                 75           150  1/10
          1336047225 packets, 427935696759 bytes
          30 second offered rate 7048000 bps, drop rate 0000 bps
          Match: any
          Queueing
          queue limit 1000 packets
          (queue depth/total drops/no-buffer drops/flowdrops) 0/410858/0/379263
          (pkts output/bytes output) 1335626673/427651330126
          bandwidth remaining 52%
          Fair-queue: per-flow queue limit 250 packets
            Mean queue depth: 2 packets
            dscp       Transmitted      Random drop      Tail/Flow drop Minimum Maximum Mark
            default1323502480/417465363429  10871/8145742    12068/6635487          600           900  1/10
            1            2068/397056          0/0              0/0                250           500  1/10
            2        11563620/9932697223   2012/1927728     6373/2760751          250           500  1/10
            4           99972/30288534       10/2368         107/14151            250           500  1/10
            cs1         1973/175307          0/0              4/264              281           500  1/10
            af11          21/3872            0/0              0/0                437           500  1/10
            af12      100100/130622932       4/6056          16/8407             375           500  1/10
            af22           3/600             0/0              0/0                375           500  1/10
            cs3        24368/20909922        0/0             13/1318             343           500  1/10
            cs5       331817/70813170        4/856          113/24182            406           500  1/10
            50            113/41573           0/0              0/0                250           500  1/10
            54            138/16508           0/0              0/0                250           500  1/10
The other worry I have is the mean queue depth for some classes are showing >0 packets, which suggests class queue-limits are not big enough.
2K is a fairly large hold queue on the interface.  I understand its not recommended to increase too much due to increase latencys so not sure I want to increase much more than that?
Can anyone assist with helping me understand this please?
yo are running hierarchical QoS, so queuing details for parent policy ("queue limit 195 packets") are meaningless and may be ignored.
Mean queue depth non-zero, while instant queue size is zero means you recently had a burst in the class. And it's completely fine to go above zero.
