Queueing strategy: fifo after configuring CBWFQ
jmaires21
Good day,
I have a router configured with CBWFQ,  I applied the service policy  on a physical interface that has 2 subinterfaces. I already read that as a best practices one should apply the service policy in the subinterfaces after. I have 2 questions
1) If I applied the service policy to the physical interfaces, will the subinterfaces inherit it?
Here is basically what im doing
policy-map CHILD
 class xxx
  bandwidth percent 10
 class yyy
 class zzz
 class aaa
  bandwidth percent 40
 class class-default
  bandwidth percent 30
  random-detect
policy-map PARENT
 class class-default
  shape average 10000000
  service-policy CHILD
interface FastEthernet3/1
 no ip address
 ip route-cache flow
 duplex full
 speed 10
 service-policy output PARENT
****no service policy applied to the subinterfaces****
2) When i do a "show interface" I see " Queueing strategy: fifo" .  I dont understand why it is not set to Queueing strategy: Class-based queueing. In other routers ive done this same configurations and the queuing strategy is Classed-based. Do you have any idea based on the configuration why this is??
ROUTER1#sh int f3/1
FastEthernet3/1 is up, line protocol is up
  MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
     reliability 255/255, txload 7/255, rxload 9/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full-duplex, 10Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/209/354 (size/max/drops/flushes); Total output drops: 566263
  Output queue: 0/40 (size/max)
  5 minute input rate 369000 bits/sec, 102 packets/sec
  5 minute output rate 275000 bits/sec, 98 packets/sec
     28296300 packets input, 1795986141 bytes
     Received 24720001 broadcasts, 0 runts, 0 giants, 0 throttles
     2 input errors, 0 CRC, 0 frame, 0 overrun, 2 ignored
     0 watchdog
     136860230 packets output, 652952945 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Okay, regardless of what the show interface shows for queuing method, you have an active CBWFQ policy on the interface.
7 Replies 7
shamax_1983
Level 3
Level 3
hi
You need to specify fair-queue in the CHILD policy under default class like so,
policy-map CHILD
 class class-default
  fair-queue
Give it a go and let us know..
Please rate helpful posts.
Hi Shamax,
Thanks for answering,
I tried your change but its still showing "Queueing strategy: fifo"
I'm going over the config over and over and I dont understand why CBWFQ after applying the service policy to the interface.
For info, im using a Cisco3845 with "c3845-ipbasek9-mz.124-25d"
Disclaimer
Posting
Could be a cosmetic bug.
What does show policy-map on interface show?
Hi Joseph,
Thanks for your time.
Here is the output of the sh policy-map int x/x output.
 Service-policy output: POLICY_WAN
    Class-map: class-default (match-any)
      8700729350 packets, 4206314501012 bytes
      5 minute offered rate 328000 bps, drop rate 0 bps
      Match: any
      Traffic Shaping
           Target/Average   Byte   Sustain   Excess    Interval  Increment
             Rate           Limit  bits/int  bits/int  (ms)      (bytes)
         10000000/10000000  62500  250000    250000    25        31250
        Adapt  Queue     Packets   Bytes     Packets   Bytes     Shaping
        Active Depth                         Delayed   Delayed   Active
        -      0         110293083 961529298 108168649 2064625915 no
      Service-policy : POLICY_WAN_QOS
        Class-map: QOS_HWK_HIPRI (match-all)
          177436234 packets, 22688136898 bytes
          5 minute offered rate 8000 bps, drop rate 0 bps
          Match: access-group name QOS_HWK_HIPRI
          Queueing
            Output Queue: Conversation 265
            Bandwidth 25 (%)
            Bandwidth 2500 (kbps)Max Threshold 64 (packets)
            (pkts matched/bytes matched) 324065/41572517
        (depth/total drops/no-buffer drops) 0/0/0
        Class-map: QOS_MANAGEMENT (match-all)
          2645440963 packets, 1348777595719 bytes
          5 minute offered rate 142000 bps, drop rate 0 bps
          Match: access-group name QOS_MANAGEMENT
          Queueing
            Output Queue: Conversation 266
            Bandwidth 5 (%)
            Bandwidth 500 (kbps)Max Threshold 64 (packets)
            (pkts matched/bytes matched) 3073222/1689835878
        Class-map: QOS_ROUTING (match-all)
          25029316 packets, 3703733836 bytes
          5 minute offered rate 0 bps, drop rate 0 bps
          Match: access-group name QOS_ROUTING
          Queueing
            Output Queue: Conversation 267
            Bandwidth 10 (%)
            Bandwidth 1000 (kbps)Max Threshold 64 (packets)
            (pkts matched/bytes matched) 4726/1939308
        Class-map: QOS_TELEPHONY (match-all)
          118 packets, 9204 bytes
          Match: access-group name QOS_TELEPHONY
          Queueing
            Output Queue: Conversation 268
            Bandwidth 10 (%)
            (pkts matched/bytes matched) 0/0
          5852822852 packets, 2831145180567 bytes
          5 minute offered rate 166000 bps, drop rate 0 bps
          Match: any
          Queueing
            Output Queue: Conversation 269
            Bandwidth 50 (%)
            Bandwidth 5000 (kbps)
            (pkts matched/bytes matched) 105233986/142641962552
        (depth/total drops/no-buffer drops) 0/501925/0
             exponential weight: 9
             mean queue depth: 0
  class    Transmitted      Random drop      Tail drop    Minimum Maximum  Mark
           pkts/bytes       pkts/bytes       pkts/bytes    thresh  thresh  prob
      0 1105641648/2794882281968 298313/374809101 202374/205299392   20      40  1/10
      1     150/18610           0/0              0/0           22      40  1/10
      2      37/2146            0/0              0/0           24      40  1/10
      3   73000/39388395        1/1518           0/0           26      40  1/10
      4      53/3074            0/0              0/0           28      40  1/10
      5 7677849/1331363548      8/848           18/2300        30      40  1/10
      6 443960666/34311937031    350/24155        861/58784       32      40  1/10
      7     330/34973           0/0              0/0           34      40  1/10
   rsvp       0/0               0/0              0/0           36      40  1/10
Disclaimer
Posting
The best way to go with this is to apply the marking on your incoming interface from the LAN. This will all the scheduler to service packets correctly then pass them to the outgoing interface. You will see FIFO on the outgoing interface until you apply a queueing strategy like Policing or Shaping.
Hope this helps
Sy
