"cisco 805 error message during boot"
fleitao
when i turn on my cisco 805 i get this message:
"Configured boot failed, attempting fallback boot."
but it works fine after finishing power on sequence.
Does anyone know waht it means?
Thanks is advanced.
Richard Burts
Francisco
This kind of message generally indicates that the configuration specifies an image file to boot but that the specified image can not be booted. A common cause of this is that the router was configured to boot a specific image file, the image was updated, the boot commands were not updated. Perhaps you can post the output of show flash and any boot commands that are in the config file.
Rick
Rick
fleitao
Rick,
Here goes what you requested:
Router#show flash:
Directory of flash:/
0 ---- 49096 Nov 08 2000 03:37:53 TinyROM-1.4(1)
1 -r-x 6673888 Mar 31 2004 22:19:25 c805-k9osy6-mw.122-13.T12.bin
104 -r-- 545 full-config
8388608 bytes total (1441792 bytes free)
Router#show ver Cisco Internetwork Operating System Software IOS (tm) C805 Software (C805-K9OSY6-MW), Version 12.2(13)T12, RELEASE SOFTWARE
(fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 31-Mar-04 12:08 by ccai
Image text-base: 0x0017F000, data-base: 0x00CB6000
ROM: TinyROM version 1.4(1)
Router uptime is 1 minute
System image file is "flash:c805-k9osy6-mw.122-13.T12.bin"
Cisco C805 (MPC850) processor (revision 0) with 54564K bytes of virtual memory.
Processor board ID FOC082307AM (1619281970)
CPU part number 0x2101
X.25 software, Version 3.0.0.
Bridging software.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial(sync/async) network interface(s)
12M bytes of physical memory (DRAM)
8K bytes of non-volatile configuration memory
8M bytes of flash on board (4M from flash card)
Configuration register is 0x102
Francisco
Thank you for posting additional information. What you posted shows that there is a single image file in flash and that is the image that the router is running.
However you did not post output from the config file. Are there any boot statements in the config file?
It would also be helpful if you would boot the router, capture the messages that are generated during the boot process and post those messages. These might help determine what the problem is.
Rick
Rick
