Wan termination on Pix firewall
talha_490
what are the possible WAN connection termination on Pix firewall 515E outside interface.
gpulos
Level 8
Level 8
ethernet, fast ethernet or gigabit ethernet are all possible terminations for the PIX towards the WAN.
mmorris11
Level 4
Level 4
The outside interface of the PIX will only terminate ethernet at 10Mbps,100Mbps, and 1000Mbps depending on how the particular device is equipped. If you need to connect the PIX to a "wan" meaning a t1 or something you have to do it indirectly with a router in front of it.
