"DNS not routable" / packets not getting out
stephen.kuhn
Hello all
I factory reset my router and re-set it up with the most basic configuration I know of. Both T1 lines check out on the web page self test dialog and can ping. However no packets can ping out from eth0.
Here is the config, (note this is not online another is at the moment, I'll fix the passwords and security once it works)
pls help
!version 12.3
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no network-clock-participate aim 0
no network-clock-participate aim 1
no aaa new-model
ip subnet-zero
ip cef
ip name-server 64.9.0.6
ip name-server 64.8.0.6
no ftp-server write-enable
username xxxx privilege 15 secret xxxx
interface FastEthernet0/0
ip address 64.x.x.x.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
ip address 64.9.x.x.x.255.252
encapsulation ppp
fair-queue
service-module t1 timeslots 1-24
interface Serial0/1/0
encapsulation ppp
fair-queue
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
ip route 0.0.0.0 0.0.0.0 Serial0/1/0
ip http server
ip http authentication local
ip http timeout-policy idle 600 life 86400 requests 10000
control-plane
! I deleted all the line stuff to shorten the screen here
scheduler allocate 20000 1000
end
Hello Stephen,
I can ping all three of your interfaces, what I cannot ping is the first name server specified in your configuration, 64.9.0.6, the second name server, 64.8.0.6, is ok. You might want to take out the line ´ip name-server 64.9.0.6´ and check if that makes a difference...
GP
The router you pinged is and old borrowed 2600 "holding down the fort" till I get this new 2811 up and running(unplugged since i'm not on site at the moment).
when you say "no packet gets out of ethernet" ... what is the interface status at this moment?
Is the device connected to the LAN to test connectivity configured correctly?
Set duplex and speed to fixed values for testing (there re sometimes issues with that).
Hope this helps
Martin
So it turns out memorydealers.com sold me two bad serial cards. Thanks to everyone for the help and advice.
I find this strange because they both passed the hardware checks in the router but I replaced them and everything works fine.
