"Failed to connect to bus: No such file or directory" on ASR 1002 x
mohammad ahmed
@Leo Laohoo Hope you are doing good. I am accessing a ASR 1002 X physical box on Rommon mode. The "dir bootflash:" is showing this below. Therefore tried to boot direct from the USB drive. Stuck with above error in the title. Can you please help me?
rommon 1 > dir bootflash:
File System: EXT2/EXT3
81921      4096      drwxrwxrwx     .installer
770049     4096      drwxrwx---     vman_fdb
262145     4096      drwxr-xr-x     .PATCH
638977     4096      drwxr-xr-x     .PATCH-backup
Output from trying to boot from the USB flash drive.
rommon 2 > boot usb0:asr1000-universalk9.16.12.08.SPA.bin
Located asr1000-universalk9.16.12.08.SPA.bin, start cluster is 221611
Image loaded
Boot image size = 817259079 (0x30b66247) bytes
ROM:RSA Self Test Passed
ROM:Sha512 Self Test Passed
Package header rev 1 structure detected
Calculating SHA-1 hash...done
validate_package_cs: SHA-1 hash:
        calculated 14f41c01:3318d886:7239633e:f2882d9f:6e225c97
        expected   14f41c01:3318d886:7239633e:f2882d9f:6e225c97
Validating main package signatures
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
  • load-cpld.service - CPLD Kernel Driver
   Loaded: loaded (/lib/systemd/system/load-cpld.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Tue 2024-07-02 12:35:50 Universal; 45ms ago
  Process: 198 ExecStart=/cpld_util.sh (code=exited, status=1/FAILURE)
 Main PID: 198 (code=exited, status=1/FAILURE)
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
>>> Rebooting
Initializing Hardware ...
System integrity status: 00000610
System Bootstrap, Version 16.7(1r), RELEASE SOFTWARE
Copyright (c) 1994-2017 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: Watchdog/ICH
SPI Flash 4KB Descriptor Area Checksum = 0x6f5a0db2
ASR1002-X platform with 8388608 Kbytes of main memory
Directory packages.conf not found
Unable to locate packages.conf directory
Unable to load packages.conf
boot: error executing "boot bootflash:packages.conf"
autoboot: boot failed, restarting...
Leo Laohoo
The firmware is not compatible to an ASR1002-X.
ASR1002-X firmware always have an "x", for example:  asr1002x-universalk9.16.12.08.SPA.bin
mohammad ahmed
@Richard Burts do you have any suggestion please? much appreciated.
Leo Laohoo
My thanks to Leo for noticing a detail that I missed.
Rick
