Redistribution Static Route on NX-OS Nexus 7000
malickmbaye
I have a N7K which is configured with multiple VDC (VDC-DIST and VDC-CORE). i have EIGRP routing activated on the two VDC and the neighboring is working fine. I am also able to redistributed direct network connected from the DIST to the CORE. But the redistribution of static routes created on DIST is not working. The CORE don't see those routes via the EIGRP. Can someone help me please, i am new on NX-OS
Configuration of DIST:
ip prefix-list REDISTRIBUTION seq 5 permit 0.0.0.0/0 le 32
route-map redist-static permit 10
match ip address prefix-list REDISTRIBUTION
redistribute direct route-map redist-static
redistribute static route-map redist-static
router eigrp VIN
autonomous-system 1
router-id 0.0.0.230
address-family ipv4 unicast
ip route 10.254.0.152/30 10.101.222.100
The route 10.254.0.152 is not seen from the CORE.
Hello
try applying the redistribution under the AFI for ipv4 also maybe tag the static instead,   then test again
router eigrp vin
no redistribute direct route-map redist-static
no redistribute static route-map redist-static
also possibly ...
ip route 10.254.0.152/30 10.101.222.100 tag 10
no route-map redist-static permit 10
match tag 10
Kind Regards
Paul
17 Replies 17
that all config, how eigrp form between two NSK SW ?
MHM
Yes The eigrp is formed:
show ip eigrp route-map statistics redistribute <<- can I see this
MHM
hello
malickmbaye
there is nothing wrong as I see
there is EIGRP and route-map is match 2 prefix
so you must see static route in other Peers
except case you have route-map to filter which prefix learn from
can you confirm that there is no route-map or distribute list filter prefix Inbound ?
also try below
instead
Nexus-C(config)# router eigrp VIN
Nexus-C(config-router)# address-family ipv4 unicast
Nexus-C(config-router-af)# autonomous-system 1
Nexus-C(config-router-af)# router-id 0.0.0.255
Nexus-C(config-router-af)# redistribute static route-map  redist-static
sometime the nexus not run command until we add it under address family
MHM
I do lab yesterday ad as I mention you need to add redistribute static under address family
Can you provide the routing table of DIST and CORE along with show ip eigrp topology on both devices.
Usually when you configure a static route and the next hop is unreachable it wont put it in the table, and therefore not redistribute it into EIGRP. If it is in fact redistributing it and passing it to its neighbor, you'll see it in the EIGRP topology table.
-David
Hello
router eigrp vin
also possibly ...
match tag 10
Kind Regards
Paul
The issue is solved with matching tag.
Thank you very much.
Did you try with tag but add under address family ipv4 unicast? i.e. NOT need TAG
FYI :-I already check it without tag and work
MHM
Will i lose the connection on the device when i apply it? Note that i am connected to an ip management which is known from eigrp
OK that need to check (lost of connection)
ip prefix-list REDISTRIBUTION seq 5 permit 0.0.0.0/0 le 32 <<- this need change to
ip prefix-list REDISTRIBUTION seq 5 permit 10.254.0.152/30
this tune the static route redistribute, but again you need to add it under address family
try it without tag and check
MHM
any update ?
MHM
