"RAM disk" emulation
Iulian Vaideanu
Level 4
Level 4
Is there any way to use the available memory of a Cisco router to create some sort of filesystem?  I'm thinking of situations when one needs to update the IOS of a remote device, but there's not enough flash space for both old and new images, transfer rate is slow and there is significant risk of power failures or reloads - "copy tftp: X:" then "copy X: flash:" (after deleting the old image) would minimize the risk of having the router restarted without a complete IOS image in its flash...
Right now I could use this for the 850 / 870 series, but I'm curious about other architectures as well.
Thank you.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Not that I'm aware of, at least for IOS based platforms.
BTW, what you might find will speed up your remote copy process, is using FTP or RCP rather than TFTP.
