"Sh ppp multi int multi X" output
lkadlik
Could someone please let me know if "unassigned" fragments indicate an issue on a multilink ?
See output below:
Multilink9, bundle name is XXX
  Bundle up for 1d12h
  0 lost fragments, 2861459 reordered, 23 unassigned
  0 discarded, 0 lost received, 2/255 load
  0x60AF3B received sequence, 0x9E46A7 sent sequence
  Member links: 4 active, 0 inactive (max not set, min not set)
    Se2/0/17:1, since 1d12h, last rcvd seq 60AF40
    Se2/0/18:1, since 1d12h, last rcvd seq 60AF65
    Se2/0/16:1, since 1d12h, last rcvd seq 60AF62
    Se2/0/4:1, since 1d12h, last rcvd seq 60AF37
Thank you.
Lynne
5 Replies 5
John Blakley
I don't have that problem with my multilinks, but I've disabled fragmentation. Are you having an issue with the link?
HTH,
John
HTH, John *** Please rate all useful posts ***
Hi John,
I am trying to figure out if we are having an issue or not. I have a customer complaining of latency to an app.  I can see the sporadically high ping times and hops in a traceroute though those can be false positive.  All the circuits are running clean and nothing is being dropped.  The only thing I saw that seemed odd is the "unassigned" fragments in the output in the post. I dont know if I should be concerned about them or not.  I searched for a while on google and could not find out anything one way or another.
Lynne
Can you post the config of that interface and the interface that's bonded to it? Take out public addressing and things....
John
interface Multilink9
description to -
ip vrf forwarding XX
ip address x.x.x.x 255.255.255.252
ip flow ingress
no cdp enable
ppp multilink
no ppp multilink fragmentation
multilink-group 9
no clns route-cache
end
sh run int Se2/0/18:1
Building configuration...
Current configuration : 235 bytes
interface Serial2/0/18:1
description T-1 to -
bandwidth 1544
no ip address
ip flow ingress
encapsulation ppp
ppp multilink
multilink-group 9
no clns route-cache
end
sh run int Se2/0/17:1
interface Serial2/0/17:1
description T-1 -
bandwidth 1544
no ip address
ip flow ingress
encapsulation ppp
ppp multilink
multilink-group 9
no clns route-cache
end
sh run int Se2/0/16:1
interface Serial2/0/16:1
description T-1 to-
bandwidth 1544
no ip address
ip flow ingress
encapsulation ppp
ppp multilink
multilink-group 9
no clns route-cache
end
sh run int Se2/0/4:1
Current configuration : 222 bytes
interface Serial2/0/4:1
description T-1 to
bandwidth 1544
no ip address
ip flow ingress
encapsulation ppp
ppp multilink
multilink-group 9
no clns route-cache
end
here you go.
Giuseppe Larosa
Hello Lynne,
I didn't find an explanation for the field in command reference
http://www.cisco.com/en/US/docs/ios/dial/command/reference/dia_s3.html#wp1056146
However, because all other counters are 0 you should be fine:
Hope to help
Giuseppe
