"show flow monitor XXX cache filter" command not available on ASR 1001?
michael.luo
I was trying to use "Top Talker" feature of Netflow on ASR 1001 running asr1001-universalk9.03.10.05.S.153-3.S5-ext.bin.
My configuration is as below:
flow monitor Temp
 record netflow ipv4 protocol-port
interface s0/1/0
 ip flow monitor Temp output
Then I tried to use the commands like "show flow monitor Temp cache filter" or "show flow monitor Temp cache sort".  However, the only option available is "format", as shown below:
ARSAN04#show flow monitor Temp cache ?
  format  Specify cache display format
  |       Output modifiers
  <cr>
Why the "sort" and "filter" options are not available?
Thanks!
0 Replies 0
