R&S lab ospf nei challenges
dchen0999
Hi, All,
It is flappy and wierd. Anyone can shed some lights?
Thanks.
Senario:
r3 hub s0/0.235 mul use nei statement - r2, r5 spoke s0/0
Problem:
1. r2 and r5 or either r2 or r5 no route from other ospf areas.
2. using "ip os ne p-mp" or "ip os ne br" or "use all physical interfaces" is fine
Note:
// osp r5 no full route
1. change router id from 2.2.5.5 to 5.5.5.5 for all routers. cle ip os proce: not working
2. reboot r3/2/5 routers: not working (r3 sub-int multipoint not working; r3 physical int works)
3. change nei statment to ip os ne p-mp: it works.
4. change from ip os ne p-mp to ip os ne p-p: not working
5. cle ip os pro for r2/3/5: still not working
6. put it back: ip os ne p-mp: it is fine.
7. however, it is required to use nei statement.
21 Replies 21
Giuseppe Larosa
Hello Dengming,
you should post the exact text of the scenario description to understand what are the requirements and the constraints.
About point-to-multipoint and neighbor command:
a Cisco proprietary version exists that is called point-to-multipoint non-broadcast.
That mode not using multicast hellos requires to use neighbor command
not receiving routes from other areas:
this should call for a totally stub area.
hub router should be ABR(0, totallystub_area)
Hope to help
Giuseppe
thanks Giuseppe.
Senario:
1. r3 hub s0/0.235 mul - r2, r5 spoke s0/0 ospf area 0: requires to use nei statement on r3
2. R3 connects to multiple ospf areas.
Problem:
r2 and r5 or either r2 or r5 gets no routes from other ospf areas
Note:
I think this is standard ospf implementation with nei statement, but it turns out it is no easy job to get it work.
ip os ne p-p = always works
ip os ne p-mp = works fine
ip os ne br = works fine
nei = works fine for hub physical interface mode
nei = NOT working or not stable in hub sub-interface mode, that is, either both spoke routers or one of the spoke router gets no route from ospf other areas.
This is wierd.
// no router with r3 using nei statement
r3#conf t
Enter configuration commands, one per line. End with CNTL/Z.
r3(config)#router os 1
r3(config-router)#nei 2.2.12.12
r3(config-router)#nei 2.2.12.13
r3(config-router)#end
Access-Server#2
[Resuming connection 2 to r2 ... ]
r2#sh ip rout
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
2.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C 2.2.2.2/32 is directly connected, Loopback0
C 2.2.12.0/24 is directly connected, Serial0/0
C 2.2.17.0/24 is directly connected, FastEthernet0/0
r2#
Access-Server#5
[Resuming connection 5 to R5 ... ]
r5#sh ip rout
C 2.2.5.5/32 is directly connected, Loopback0
C 2.2.17.0/24 is directly connected, FastEthernet0/1
150.2.0.0/24 is subnetted, 1 subnets
C 150.2.2.0 is directly connected, FastEthernet0/0
r5#
Access-Server#3
[Resuming connection 3 to R3 ... ]
// changing to "ip os ne p-mp" routes show up from other ospf areas
r3#conf t
r3(config-router)#no nei 2.2.12.13
*Jun 16 17:45:02.901: %OSPF-5-ADJCHG: Process 1, Nbr 0.0.0.0 on Serial0/0.235 fr
om ATTEMPT to DOWN, Neighbor Down: Neighbor deconfigured
r3(config-router)#no nei 2.2.12.12
r3(config-router)#
*Jun 16 17:45:05.513: %OSPF-5-ADJCHG: Process 1, Nbr 0.0.0.0 on Serial0/0.235 fr
r3(config-router)#int s0/0.235
r3(config-subif)#ip os ne p
r3(config-subif)#ip os ne point-to-m
r3(config-subif)#
Access-Server#2
r2#conf t
r2(config)#int s0/0
r2(config-if)#ip os ne po
r2(config-if)#ip os ne point-to-m
r2(config-if)#
Access-Server#5
r5#conf t
r5(config)#int s0/0
r5(config-if)#ip os ne po
r5(config-if)#ip os ne point-to-m
r5(config-if)#
*Feb 4 03:29:09.656: %OSPF-5-ADJCHG: Process 1, Nbr 3.3.3.3 on Serial0/0 from L
OADING to FULL, Loading Done
r5(config-if)#end
r5#sh ip rout
*Feb 4 03:29:14.488: %SYS-5-CONFIG_I: Configured from console by console
r5#sh ip rout
Codes: C - connected, S - static, R - ....
2.0.0.0/8 is variably subnetted, 12 subnets, 3 masks
O 2.2.12.12/32 [110/128] via 2.2.12.11, 00:00:01, Serial0/0
O IA 2.2.6.6/32 [110/66] via 2.2.12.11, 00:00:01, Serial0/0
O IA 2.2.4.4/32 [110/129] via 2.2.12.11, 00:00:01, Serial0/0
O 2.2.3.3/32 [110/65] via 2.2.12.11, 00:00:01, Serial0/0
O 2.2.2.2/32 [110/129] via 2.2.12.11, 00:00:01, Serial0/0
O IA 2.2.1.1/32 [110/130] via 2.2.12.11, 00:00:01, Serial0/0
O 2.2.12.11/32 [110/64] via 2.2.12.11, 00:00:02, Serial0/0
O IA 2.2.8.0/21 [110/65] via 2.2.12.11, 00:00:02, Serial0/0
O IA 2.2.16.0/24 [110/128] via 2.2.12.11, 00:00:02, Serial0/0
r5#
Access-Server#2
*Mar
r2(config-if)#end
r2#sh ip
*Mar 14 07:11:07.698: %SYS-5-CONFIG_I: Configured from console by console
r2#sh ip rout
O IA 2.2.6.6/32 [110/66] via 2.2.12.11, 00:00:08, Serial0/0
O 2.2.5.5/32 [110/129] via 2.2.12.11, 00:00:08, Serial0/0
O IA 2.2.4.4/32 [110/129] via 2.2.12.11, 00:00:08, Serial0/0
O 2.2.3.3/32 [110/65] via 2.2.12.11, 00:00:08, Serial0/0
O IA 2.2.1.1/32 [110/130] via 2.2.12.11, 00:00:08, Serial0/0
O 2.2.12.13/32 [110/128] via 2.2.12.11, 00:00:08, Serial0/0
O 2.2.12.11/32 [110/64] via 2.2.12.11, 00:00:09, Serial0/0
O IA 2.2.8.0/21 [110/65] via 2.2.12.11, 00:00:09, Serial0/0
O IA 2.2.16.0/24 [110/128] via 2.2.12.11, 00:00:09, Serial0/0
r2#
Hello Dengming,
this is a subtle issue:
when the IP OSPF network type is different on the two sides of a link even if the OSPF neighborship says it is up the other router cannot install in its routing tables the routes received by the other router even if actually received during the loading phase.
the OSPF network type must match.
you can compare the network type using
sh ip ospf interface type x/y
Hope to help
Giuseppe
Additional to Giuseppe's comment on network type. They network type needs to be matched or compatible with each other, like
- point-to-point is compatible with point-to-multipoint, but you need to make sure the hello and dead intervals are match
- broadcast is compatible with non-broadcast, but you need to make sure the hello and dead intervals are match
HTH,
jerry
Thanks Giuseppe and Jerry.
But how to make nei work, as nei is required and no way to bypass.
// all Network Type NON_BROADCAST
r3#sh ip os int s0/0.235
Serial0/0.235 is up, line protocol is up
Internet Address 2.2.12.11/29, Area 0
Process ID 1, Router ID 3.3.3.3, Network Type NON_BROADCAST, Cost: 64
r2#sh ip os int s0/0
Serial0/0 is up, line protocol is up
Internet Address 2.2.12.12/24, Area 0
Process ID 1, Router ID 2.2.2.2, Network Type NON_BROADCAST, Cost: 64
Transmit Delay is 1 sec, State DROTHER, Priority 0
No designated router on this network
No backup designated router on this network
Timer intervals configured, Hello 30, Dead 120, Wait 120, Retransmit 5
r5#sh ip os int s0/0
Internet Address 2.2.12.13/24, Area 0
Process ID 1, Router ID 5.5.5.5, Network Type NON_BROADCAST, Cost: 64
r5#sh ip os nei
r5#
r2#sh ip os nei
r2#
r3#sh ip os nei
Neighbor ID Pri State Dead Time Address Interface
N/A 0 ATTEMPT/DROTHER - 2.2.12.12 Serial0/0.235
N/A 0 ATTEMPT/DROTHER - 2.2.12.13 Serial0/0.235
2.2.7.7 1 FULL/BDR 00:00:34 2.2.13.7 FastEthernet0/
2.2.9.9 1 FULL/DR 00:00:32 2.2.13.9 FastEthernet0/
6.6.6.6 1 2WAY/DROTHER 00:00:37 2.2.13.1 FastEthernet0/
2.2.8.8 1 FULL/BDR 00:00:31 2.2.10.8 FastEthernet0/
4.4.4.4 0 FULL/ - 00:00:31 2.2.16.4 Serial0/1
r3#
Without seeing your configuration, I can't really tell what is wrong. However, I have tested the condition you've described, and I am able to get it to work, please see below:
! R3
interface Serial0/0
no ip address
encapsulation frame-relay
no frame-relay inverse-arp
interface Serial0/0.333 multipoint
ip address 152.1.123.3 255.255.255.0
frame-relay map ip 152.1.123.1 301
frame-relay map ip 152.1.123.2 302
router ospf 1
log-adjacency-changes
network 150.1.3.3 0.0.0.0 area 0
network 152.1.123.3 0.0.0.0 area 0
neighbor 152.1.123.1
neighbor 152.1.123.2
! R1
interface Serial0/0
ip address 152.1.123.1 255.255.255.0
ip ospf priority 0
frame-relay map ip 152.1.123.3 103
frame-relay map ip 152.1.123.2 103 !<- next hop resolution for networks adv by R2
router ospf 1
network 150.1.1.1 0.0.0.0 area 0
network 152.1.123.1 0.0.0.0 area 0
! R2
interface Serial0/0
ip address 152.1.123.2 255.255.255.0
ip ospf priority 0
frame-relay map ip 152.1.123.3 203
frame-relay map ip 152.1.123.1 203 !<- next hop resolution for networks adv by R1
router ospf 1
network 150.1.2.2 0.0.0.0 area 0
network 152.1.123.2 0.0.0.0 area 0
Here is the show output
! R3
Rack1R3#sh frame map
Serial0/0.333 (up): ip 152.1.123.1 dlci 301(0x12D,0x48D0), static,
CISCO, status defined, active
Serial0/0.333 (up): ip 152.1.123.2 dlci 302(0x12E,0x48E0), static,
Rack1R3#sh ip ospf nei
150.1.1.1 0 FULL/DROTHER 00:01:58 152.1.123.1 Serial0/0.333
150.1.2.2 0 FULL/DROTHER 00:01:34 152.1.123.2 Serial0/0.333
Rack1R3#sh ip ospf int s0/0.333
Serial0/0.333 is up, line protocol is up
Internet Address 152.1.123.3/24, Area 0
Process ID 1, Router ID 150.1.3.3, Network Type NON_BROADCAST, Cost: 64
Transmit Delay is 1 sec, State DR, Priority 1
Designated Router (ID) 150.1.3.3, Interface address 152.1.123.3
Neighbor Count is 2, Adjacent neighbor count is 2
Adjacent with neighbor 150.1.1.1
Adjacent with neighbor 150.1.2.2
Suppress hello for 0 neighbor(s)
! R1
Rack1R1#sh frame map
Serial0/0 (up): ip 152.1.123.3 dlci 103(0x67,0x1870), static,
Rack1R1#sh ip ospf nei
150.1.3.3 1 FULL/DR 00:01:32 152.1.123.3 Serial0/0
Rack1R1#sh ip ospf int s0/0
Internet Address 152.1.123.1/24, Area 0
Process ID 1, Router ID 150.1.1.1, Network Type NON_BROADCAST, Cost: 64
! R2
Rack1R2#sh frame map
Serial0/0 (up): ip 152.1.123.3 dlci 203(0xCB,0x30B0), static,
Rack1R2#sh ip ospf nei
150.1.3.3 1 FULL/DR 00:01:30 152.1.123.3 Serial0/0
Rack1R2#sh ip ospf int s0/0
Internet Address 152.1.123.2/24, Area 0
Process ID 1, Router ID 150.1.2.2, Network Type NON_BROADCAST, Cost: 64
jerry
wow. thanks Jerry for your great effort to the help.
I do extra test again for another lab: the hub s0/0.134 mul to r3, r4 spoke s0/0 nei statement with same thing r3, or r4 no route from ospf other areas.
No worry. I will see if I will put together all the config files for your check later on.
Thanks again Jerry and All for the great help and have a wonderful day.
It is lucky to get it working tonight.
Thanks Jerry. I am good. I will keep watch on this and will update this as needed.
R5#
interface Serial0/0
no ip address
frame-relay lmi-type cisco
interface Serial0/0.125 multipoint
ip address 2.2.125.5 255.255.255.0
ip ospf priority 255
snmp trap link-status
frame-relay map ip 2.2.125.1 501 broadcast
frame-relay map ip 2.2.125.2 502 broadcast
frame-relay map ip 2.2.125.5 501
router ospf 1
network 2.2.5.5 0.0.0.0 area 0
network 2.2.125.5 0.0.0.0 area 0
neighbor 2.2.125.1
neighbor 2.2.125.2
R1#
interface Serial0/0
ip address 2.2.125.1 255.255.255.0
ip ospf priority 0
no dce-terminal-timing-enable
frame-relay map ip 2.2.125.1 105
frame-relay map ip 2.2.125.2 105 broadcast
frame-relay map ip 2.2.125.5 105 broadcast
interface Serial0/1
ip address 2.2.13.1 255.255.255.0
ip ospf network point-to-point
frame-relay map ip 2.2.13.1 113
frame-relay map ip 2.2.13.3 113 broadcast
router ospf 1
network 2.2.1.1 0.0.0.0 area 0
network 2.2.13.1 0.0.0.0 area 13
network 2.2.125.1 0.0.0.0 area 0
R2#
interface Serial0/0
ip address 2.2.125.2 255.255.255.0
ip ospf priority 0
frame-relay map ip 2.2.125.1 205 broadcast
frame-relay map ip 2.2.125.2 205
frame-relay map ip 2.2.125.5 205 broadcast
router ospf 1
network 2.2.2.2 0.0.0.0 area 0
network 2.2.125.2 0.0.0.0 area 0
r5#sh ip os nei
2.2.1.1 0 FULL/DROTHER 00:01:57 2.2.125.1 Serial0/0.125
2.2.2.2 0 FULL/DROTHER 00:01:59 2.2.125.2 Serial0/0.125
r1#sh ip os nei
2.2.5.5 255 FULL/DR 00:01:55 2.2.125.5 Serial0/0
2.2.3.3 0 FULL/ - 00:00:30 2.2.13.3 Serial0/1
r2#sh ip os nei
2.2.5.5 255 FULL/DR 00:01:50 2.2.125.5 Serial0/0
r2#sh ip rou
2.0.0.0/8 is variably subnetted, 11 subnets, 2 masks
O IA 2.2.7.7/32 [110/130] via 2.2.125.1, 00:00:24, Serial0/0
O 2.2.5.5/32 [110/65] via 2.2.125.5, 00:01:58, Serial0/0
O IA 2.2.3.3/32 [110/129] via 2.2.125.1, 00:00:34, Serial0/0
O 2.2.1.1/32 [110/65] via 2.2.125.1, 00:01:58, Serial0/0
O IA 2.2.12.0/24 [110/129] via 2.2.125.1, 00:00:19, Serial0/0
O IA 2.2.13.0/24 [110/128] via 2.2.125.1, 00:01:58, Serial0/0
r1#sh ip rout
2.0.0.0/8 is variably subnetted, 8 subnets, 2 masks
O 2.2.7.7/32 [110/66] via 2.2.13.3, 00:00:30, Serial0/1
O 2.2.5.5/32 [110/65] via 2.2.125.5, 00:01:41, Serial0/0
O 2.2.3.3/32 [110/65] via 2.2.13.3, 00:00:30, Serial0/1
O 2.2.2.2/32 [110/65] via 2.2.125.2, 00:01:41, Serial0/0
C 2.2.1.1/32 is directly connected, Loopback0
O 2.2.12.0/24 [110/65] via 2.2.13.3, 00:00:30, Serial0/1
r5#sh ip rout
2.0.0.0/8 is variably subnetted, 10 subnets, 2 masks
O IA 2.2.7.7/32 [110/130] via 2.2.125.1, 00:00:37, Serial0/0.125
O IA 2.2.3.3/32 [110/129] via 2.2.125.1, 00:00:47, Serial0/0.125
O 2.2.2.2/32 [110/65] via 2.2.125.2, 00:02:11, Serial0/0.125
O 2.2.1.1/32 [110/65] via 2.2.125.1, 00:02:11, Serial0/0.125
O IA 2.2.12.0/24 [110/129] via 2.2.125.1, 00:00:32, Serial0/0.125
O IA 2.2.13.0/24 [110/128] via 2.2.125.1, 00:02:11, Serial0/0.125
Okay, thanks for letting me know.
jerry
