random NAT working / not working with CEF load balancing
matej.pisek
I had a few static NAT problems last week when configuring CIsco 892.
I have 2 Dialers for PPPoE and CEF - per-destination load balancing. Everything is ok but static NAT which it doesn't work! Or... it work randomly... yes/no, yes/no,... sometimes i can't ping WAN's from the outside...
IOS is 15.0 tried 15.2, 12.4
Config is like this...
! No configuration change since last restart
version 15.0
hostname mad-router1
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone CET 1
clock summer-time CET recurring last Sun Mar 2:00 last Sun Oct 3:00
ip source-route
ip dhcp excluded-address 192.168.235.201 192.168.235.255
ip dhcp excluded-address 192.168.235.1 192.168.235.100
ip dhcp excluded-address 192.168.11.201 192.168.11.255
ip dhcp pool LAN
   import all
   network 192.168.235.0 255.255.255.0
   default-router 192.168.235.3
   domain-name office.mad.net
   dns-server 192.168.235.3
   lease 3
ip cef
ip domain name office.mad.net
ip name-server 217.237.151.142
no ipv6 cef
license udi pid CISCO892-K9 sn FCZ1538C5Q2
ip ssh version 2
track 1 interface Dialer1 ip routing
track 2 interface Dialer2 ip routing
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
description LAN
interface FastEthernet1
description VOIP
switchport access vlan 2
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
description WAN02
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 2
no cdp enable
interface GigabitEthernet0
description WAN01
no ip address
duplex auto
speed auto
pppoe-client dial-pool-number 1
no cdp enable
interface Vlan1
description LAN
ip address 192.168.235.3 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Vlan2
description VOIP
ip address 192.168.11.1 255.255.255.0
ip nat inside
interface Dialer1
description PPoE for T-Home modem (white)
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxx1
ppp chap password 0 xxxxxxx1
ppp pap sent-username xxx1 password 0 xxxxxxx1
interface Dialer2
description PPoE for Linksys/Cisco modem (black)
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
ppp chap hostname xxx2
ppp chap password 0 xxxxxxx2
ppp pap sent-username xxx2 password 0 xxxxxxx1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source static tcp 192.168.235.9 80 interface Dialer1 80
ip nat inside source static tcp 192.168.235.3 23 interface Dialer1 23
ip nat inside source static tcp 192.168.235.10 9000 interface Dialer1 9000
ip nat inside source static tcp 192.168.235.10 443 interface Dialer1 443
ip nat inside source static tcp 192.168.235.10 3389 interface Dialer1 3389
ip nat inside source static tcp 192.168.235.3 22 interface Dialer1 22
ip nat inside source route-map dialer1-rm interface Dialer1 overload
ip nat inside source route-map dialer2-rm interface Dialer2 overload
ip route 0.0.0.0 0.0.0.0 Dialer1 track 1
ip route 0.0.0.0 0.0.0.0 Dialer2 track 2
access-list 121 permit ip 192.168.235.0 0.0.0.255 any
access-list 121 permit ip any any
access-list 151 permit ip 192.168.235.0 0.0.0.255 192.168.105.0 0.0.0.255
access-list 151 permit ip 192.168.235.0 0.0.0.255 192.168.234.0 0.0.0.255
access-list 151 permit ip 192.168.235.0 0.0.0.255 192.168.233.0 0.0.0.255
access-list 151 permit ip 192.168.235.0 0.0.0.255 192.168.240.0 0.0.0.255
route-map dialer1-rm permit 10
match ip address 121
match interface Dialer1
route-map dialer2-rm permit 10
match interface Dialer2
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
11 Replies 11
What error messages do you get? Also what IOS do you have? Did you try to see if there are any bugs with your existing IOS . Maybe its a buggy IOS
I get no error message.... "ip show nat tran" shows everything is ok... i conected from random port from another ISP IP...
Pro Inside global      Inside local       Outside local      Outside global
tcp 217.92.124.141:23  192.168.235.3:23   178.25.80.236:39377 178.25.80.236:39377
tcp 217.92.124.141:443 192.168.235.10:443 ---                ---
tcp 217.92.124.141:3389 192.168.235.10:3389 ---              ---
Hi,,
Maybe this  thread can help you a bit?
https://supportforums.cisco.com/message/3299022#3299022
tryed it not working for me...
i don't get it CEF should work... what am i doing wrong here!?!??!
matej.pisek
I've found another strange thing... if i first ping the static WAN interface that should have static NAT working and get no answer than NAT will work... if i restart the router and get ping reply the NAT won't work...
You should be having 2 static PAT entries with the keyword extendable for each service you want to be accessible from outside each pointing to a different interface like this:
ip nat inside source static tcp 192.168.235.9 80 interface Dialer1 80 extendable
ip nat inside source static tcp 192.168.235.9 80 interface Dialer2 80 extendable
Alain.
Hi Alain,
What happens in this case? His translations work but he can't ping the WAN interface??
Hey Kishore...
Well I added ip nat enable to vlan1... still random NAT working/not working...
NAT translations still show a connection when i try to telnet, rdp, https,.... But connection still isn't made.
I can't ping the global inside address in your NAT translation table and you haven't got any ACL applied or firewall configured so that's strange.
Can you do a debug ip icmp and debug ip pack detail 199 while pinging this address from outside
where 199 is an ACL permitting icmp traffic.
Alain.
Hello Matej,
I have given only a quick look to the thread, however there are some points:
in order to have NAT to co-exist with two routers and two PPPoE dialer WAN interfaces you need to solve any possible ambiguity:
given an internal server X serving on TCP  port Y at a given time that server has to be reachead only by R1 or by R2 both directions
the random results look like to come out from your setup that does not provide per flow path choice (both directions)
this may require a lot of additional work or you can you use stateful NAT without any load balancing effect.
edit:
if the router is only one in your tests PBR could be of help.
is the second 892 in the same site or in another one?
the test should be done accessing server X on TCP port Y as in configuration everything else may be misleading
Hope to help
Giuseppe
Hey! Giuseppe... But isn't statefull NAT used only with two physical routers for redundancy purpose?
This routers are on two totaly different locations. They are not ment to be used together for load balancing since 892 allready has two wan ports (GE0 and FE8).
