Rate limit a subnet with shaping as opposed to policy
atmpinniatm
My research has lead me to 2 areas for  configuration of shaping. Apply shaping on class-map and/or the policy-map??
Objective = limit subnet to 256K at all times.
Access-list 1 permit <subnet>
Class-map 256k_limit
Match access-group 1
bandwidth  256000 (not sure if this is required/relevant)
shape  peak 256000
policy-map  256K_choke
class  256k_limit
(perhaps shaping should be applied here??)
int  xyz
service-policy output 256K_choke (FYI data to be choked comes in on interface  abc and out on xyz)
I understand from my previous discussion/port that shaping will provide users on subnet xyz with better performance as buffering would be used should bandwidth increase above 256K.
This is my previous solution with policy
access-list 1 permit <subnet>
class-map 256_limit
match access-group 1
exit
policy-map subn_rate_limit
class 256_limit
police 256000 conform-action transmit  exceed-action drop  violate-action drop
interface g0/0
service-policy output subn_rate_limit
Am on on the right track?
Giuseppe Larosa
Hello John,
you are on the right track
Class based shaping can be applied outbound and the change is in the policy-map configuration where the action is changed from police .... to shape.
see command reference for shape command in policy map context
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_s1.html#wp1068912
Hope to help
Giuseppe
Giuseppe Larosa
Hello John,
Hope to help
Giuseppe
