Rate-limit CIR/bc/be Confusion
Rupesh Kashyap
Hi, I have to limit WWW Syn packet to 500Kbs. I am confused by CIR, be & be has been choosen like following --
access-list 192 permit tcp any any eq www sync
int f0/1
rate-limit output access-group 192 496000 4000 4000 conform-action permit exceed-action drop
5 Replies 5
andrew.prince
Level 10
Level 10
The recommended be values are 2 x the CIR - otherwise you run the risk of global sync.
HTH>
Istvan_Rabai
Level 7
Level 7
Hi Rupesh,
Don't forget the following:
496000 means cir in bits per second (bps).
4000 means bc and be in BYTES.
For rate limiting the recommended values for bc and be are the following:
bc = (1.5 x cir)/8
be = 2 x bc
This would mean the following recommended configuration for the rate limit command:
rate-limit output access-group 192 496000 93000 186000 conform-action permit exceed-action drop
Cheers:
Istvan
1. At first, I have requested for 500kbs, they why CIR is 496kbs ?
2. Bc will CIRx125ms, which is not 93000 ?
3. Why be = 2x bc
Hi Rupesh,
The following link will give some more explanations on rate-limiting and the recommended settings for bc and be.
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfpolsh.html#wp1000920
Cheers:
Istvan
Joseph W. Doherty
BTW, I wonder whether your requirement might be better provided by something like the "TCP Intercept" feature.
