Rate Limit FTP and File Copying 445 Port
imranraheel
I want to implement a policy so the specifed two protocols cant use more than 50 % of my WAN bandwidth ,
What policy should i implement.
Hello
You can class based policing for these protocols depending on the device you want apply this to.
can you post the details.of the switch/router also protocols involved and interface bw rates
res
paul
Can
Sent from Cisco Technical Support Android App
Kind Regards
Paul
rizwanr74
Level 7
Level 7
Hello Imran,
Please check this thread below, a solution has been been given with an example easy to follow and you can customize it per two specific porotocols as per your need.
http://supportforums.cisco.com/message/3931108#3931108
Rizwan Rafeek
Pls rate helpful posts.
Bilal Nawaz
You can police inbound and outbound depending on if your platform supports it.
Lets say i wanted to limit to 50% up and down for port 445 AND FTP - you can do this, For anything using port 445 and FTP (in this example):
### To match the traffic
ip access-list extended ACL_HALF
permit tcp any any eq 445
permit tcp any any eq FTP
### Class the traffic
class-map Link_HALF
match access-group ACL_HALF
### Apply policy against the class (type of traffic specified by your class-map)
policy-map Policy_HALF
class Link_HALF
   police rate percent 50
     conform-action transmit
     exceed-action drop
interface gigabitethernet1/0
### Applies the policies inbound and outbound, both directions
service-policy input Policy_HALF
service-policy output Policy_HALF
Where the ACL is you can specify source and destination or just source or source and port depending on how you configure your ACL. You can also specify a burst rate.
Hope this helps.
Link for your reference:
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfpoli_ps1835_TSD_Products_Configuration_Guide_Chapter.html#wp1006389
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Hello
I would suggest to created two class map statements and police on each of the class's - Having the default match-all for the class map - meaning for a match to be true , a match on both protocols is required and if this isn't made on both of these then the Class will not be processed.
Also use the police /police cir commands (data plane) would be an more optimal choice - As the police rate statement is for cpp ( control plane policing)
Res
Paul
Kind Regards
Paul
