rate limit port in TCP protocol
ksvy_ksvy
not able to find a traffic shaping utility that would rate limit a port of TCP protocol in a GRE infrastructure. GTS would be perfect, but it doesn't work in a GRE tunnel.
Any suggestions?
thanks, Kevin
Giuseppe Larosa
Hello Kevin,
you should try to use Class based Shaping with modular QoS
see
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/reg_pkt_flow_shaping.html
Hope to help
Giuseppe
Giuseppe, excellent launch URL into QoS. My concern is, I think most traffic shaping QoS is applied on the out-going interface.
In my implementation, the remote site's WAN connection is an Ethernet ISP hand-off. This remote site is to be a "spoke" in a DMVPN infrastructure.
We're going to GRE "EIGRP" out to remote spokes as this one. So ultimately,
the question is "can you use traffic shaping in a DMVPN solution using GRE?"
