Rate-limit
richard.gosling
I want to reduce a line from 100 meg to 20 meg
Can any assist me in unerstanding rate-limit.
Or is it better to traffic shape
Many thanks
10 Replies 10
Jon Marshall
Richard
policy-map Shape-all-20
class class-default
shape average 20000000
int fa0/1
service-policy output Shape-all-20
where fa0/1 is the interface you want to do the shaping on.
Shaping is generally better than strict rate-limiting as instead of just dropping packets it smooths out the bursts of traffic.
Jon
Jon
Thats clear so what would this statment produce:
rate-limit input 20000000 30000000 40000000 conform-action transmit exceed-action drop
rate-limit output 20000000 30000000 40000000 conform-action transmit exceed-action drop
cheers Richard
cisco_lad2004
Level 5
Level 5
U have 2 options:
1-Shaping as per Jon's post, which will buffer and gives users a better experience.
2-strict policing is as you mentionned. personally, I prefer below command ( in a policy map).
police BW bps BURST byte conform-action transmit exceed-action drop
Though shaping is better as it does not drop when it can buffer. But it is CPU taxing.
Policing is stricter, but not so hard on CPU.
Sam
How do I configure this?
I just trying to get my head round this
I need a policy-map also a class map and bind it to the interface right ?
policy-map LIMIT
class class-default
police 5.5 mbps 400 kbyte conform-action transmit exceed-action drop
#under interface#
service-policy output LIMIT
ok so when I enter police 200000000 (normal burst bytes)
what does normal burst bytes do?
use 1/4 of that, then divide further by 8 to get the value in Byte..or simply divide by 32.
its just a guidelines I use sometimes.
Does not like this to much
(config-if)#service-policy output
LTS_TRAFFIC_SHAPE
Configuration failed!
Warning: Assigning a policy map to the output side of an interface not supported
depends on platform, and maybe also interface type.
are u on a 35XX and Interface VLAN ?
3750 Gigeth
