Rate limiting not working on 6504E
exchange1
I limit my customers on 6504E using rate-limiting but the customers shoot beyond the rate-limit.I configure rate-limiting on Cisco 6504E with the following cards:
IOS:
s72033-advipservicesk9_wan mz.122-18.SXF8.bin
Cards
Supervisor Engine 720 (Active) WS-SUP720-3B
SFM-capable 16 port 10/100/1000mb RJ45 WS-X6516-GE-TX
interface GigabitEthernet4/3
ip address X.X.X.X
ip nat outside
NO rate-limit input 45000000 5625000 11250000 conform-action transmit exceed-action drop
no rate-limit output 45000000 5625000 11250000 conform-action transmit exceed-action drop
no cdp enable
Marwan ALshawi
use policing with policy map better
for example
acceess-lis 100 permit ip [source] [distnation]
class-map map1
match access-group 100
policy-map policy1
class map1
police 450000 conform-action transmit exceed-action drop
then apply it to the interface
like
interface [port number]
service-policy input policy1
good luck
if helpful Rate
Joseph W. Doherty
What might be happening, your policier is allowing bursts. If your reduce your burst size (or interval), the policier will behave more like a physical interface for that data rate, although also acting like an interface with a small queue. If supported, you might consider using a shaper to regulate speed. As you reduce the burst size, it too behaves more like a physical interface for that data rate but it queues the excess instead of dropping it.
