04-13-2023 01:46 AM
This is the current ACL that is blocking this range.
410 deny ip any 10.250.0.0 0.0.255.255
I want to allow just 1 host from the above range to go through
04-13-2023 01:34 AM
Hi Guys
I have access list that deny a range of IPs to the internet.
I want to allow individual host to internet to talk to a server in the internet. can you please help?
04-17-2023 12:58 PM
@Sectech1 you can add allowed host entry on high priority on existing ACL, like
409 permit ip any <IP_you_Want_to_Allow> 0.0.0.0
if still you facing issue, i would request please share output of below commands
04-13-2023 09:45 AM
You should probably read and understand these pages to get a basic understanding of how ACLs work:
https://www.cisco.com/c/en/us/support/docs/ip/access-lists/26448-ACLsamples.html
https://www.cisco.com/c/en/us/support/docs/security/ios-firewall/23602-confaccesslists.html
And if you search you'll find hundreds of examples and videos.
In this case you just need to insert a line before 410 with:
"permit ip host <ip address> any" or maybe "permit ip any host <ip address>" depending on where your ACL is configured and which direction you're filtering the traffic.
04-13-2023 10:47 AM
Hello
So then you would need to amend that access-list to permit that single host and to do that an additional access-list control entry (ace) needs to be added and serviced before that 410 deny ace
example:
ip access-list extended xxx
409 permit ip any host 10.250.x.x
04-13-2023 05:12 PM
Paul's provided the direct answer.
To be clear, the x.x in 10.250.x.x would be any specific/one address, from 10.250.0.0 to 10.250.255.255. I.e. although for a /16, the useable range is 10.250.0.1 to 10.250.255.254, the new ACE matches one address within the /8 address block range.
Paul also shows the new ACE with a sequence number of 209.
First, it's possible 209 is being used. Second, what's important is the new permit ACE is before the current deny ACE. Third, having the two ACEs, back to back, is helpful from a maintenance standpoint.
04-13-2023 10:48 AM
what direction of this ACL ?
