Re: ACL entry for netbios-ss
ambivert skill
Hi ,
I am trying to find the difference between the line mentioned in ACL
1.deny udp any any range 135 netbios-ss
2.deny tcp any any range 135 139 .
SMB (Server Message Block) protocol is used among other things for file  sharing in Windows NT/2000/XP. In Windows NT it ran on top of NetBT  (NetBIOS over TCP/IP), which used the famous ports 137, 138 (UDP) and  139 (TCP).
so what is the special purpose of first ACL line.
cadet alain
netbios-ss is port 139 tcp and udp so these are the same lines except for the transport protocol.
Alain
cadet alain
Alain
Thanks for your reply suppose if these lines are for TCP only then it mean the same thing
1.deny tcp any any range 135 netbios-ss
Ambivert
