Cisco 888 NAT problems
Ivan Tesselaar
I configured my 888 and all seems to be working ok. I can reach the internet, i can reach the PC, and "sh ip nat trans" is showing me entries. But for some reason the PC is not able to connect to the internet. I tried all different settings, but i cannot figure out why this is not working. Not really sure anymore if this is a NAT problem or something else...
rtrsdsl#sh run
Building configuration...
Current configuration : 6898 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname rtrsdsl
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 51200
logging console critical
enable secret 5 xxx
no aaa new-model
clock timezone PCTime 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
crypto pki trustpoint TP-self-signed-623211236
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-623211236
revocation-check none
rsakeypair TP-self-signed-623211236
crypto pki certificate chain TP-self-signed-623211236
certificate self-signed 01
  xxx
quit
no ip source-route
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.31.20.254
ip dhcp pool ccp-pool
   import all
   network 10.31.20.0 255.255.255.0
   default-router 10.31.20.253
   dns-server 8.8.8.8
   lease 0 2
ip dhcp pool IAS
   import all
   origin ipcp
ip cef
no ip bootp server
no ip domain lookup
ip domain name paramelt.com
no ipv6 cef
username xxx privilege 15 secret 5 xxx
archive
log config
  hidekeys
controller DSL 0
mode atm
line-mode auto enhanced
dsl-mode shdsl symmetric annex B
ip tcp synwait-time 10
ip ssh source-interface Vlan1
ip ssh version 2
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol h323
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class class-default
  drop
class class-default
  drop
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface ATM0.1 point-to-point
no ip redirects
ip flow ingress
pvc 2/32
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
switchport access vlan 2
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
ip address 10.31.20.253 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
zone-member security in-zone
ip tcp adjust-mss 1452
interface Vlan2
ip address pool IAS
shutdown
interface Dialer0
ip address negotiated
ip verify unicast reverse-path
no ip redirects
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname KPN
ppp chap password 7 xxx
ppp pap sent-username kpn password 7 xxx
ppp ipcp dns request
ppp ipcp mask request
ppp ipcp address accept
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 10.31.0.0 255.255.255.0 10.31.20.254
ip route 10.31.0.150 255.255.255.255 10.31.20.254
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 10 interface Dialer0 overload
logging trap debugging
access-list 10 permit 10.31.20.0 0.0.0.255
access-list 23 permit 10.31.0.0 0.0.255.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip xxx.xxx.94.192 0.0.0.7 any
access-list 100 permit ip 10.31.20.0 0.0.0.255 any
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
rtrsdsl#sh ip nat trans
Pro Inside global         Inside local          Outside local         Outside global
icmp xxx.xxx.94.193:11894  10.31.20.36:11894     8.8.8.8:11894         8.8.8.8:11894
udp xxx.xxx.94.193:41263   10.31.20.36:41263     8.8.8.8:53            8.8.8.8:53
udp xxx.xxx.94.193:44634   10.31.20.36:44634     8.8.8.8:53            8.8.8.8:53
rtrdsl#debug ip nat
rtrdsl#sh log
015049: *Mar 12 11:43:28.785 PCTime: NAT*: s=8.8.8.8, d=xxx.xxx.94.193->10.31.20.36 [0]
015050: *Mar 12 11:43:29.773 PCTime: NAT*: s=10.31.20.36->xxx.xxx.94.193, d=8.8.8.8 [0]
2 Accepted Solutions
you have an inside zone but no outside zone so by default all traffic from a zone to a non zone member is dropped.
try this:
int dialer1
Regards.
Alain
no access-list 100 permit ip 10.31.20.0 0.0.0.255 any
Regards.
Alain
8 Replies 8
jawad-mukhtar
Level 4
Level 4
Issue these command on you Dialer Interface.
interface Dialer1
mtu 1492
** Do Rate Helpful Posts**
Jawad
It's not working.
But the internet connection is working, so i don't understand what your suggestion might do to help? And I assume you meant Dialer0?
try this:
int dialer1
Regards.
Alain
Hello Ivan,
If I understand correctly, internet connection is working if you are trying from router, but your PC has no connection to internet.
Try remove this command ->
interface Vlan1
no zone-member security in-zone
I noticed that your outside interface Dialer0 is not member of any security zone.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
I get the feeling this is the right direction, but not really working yet. I do like to keep a security zone.
I added the security zone:
interface Dialer0
mtu 1492
no ip redirects
ip flow ingress
ip nat outside
zone-member security out-zone
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
rtrdsl#debug zone security events
rtrdsl#sh log
017570: *Mar 12 14:05:53.132 PCTime: %FW-6-DROP_PKT: Dropping icmp session 10.31.20.36:0 8.8.8.8:0 on zone-pair ccp-zp-in-out class ccp-invalid-src due to  DROP action found in policy-map with ip ident 0
017642: *Mar 12 14:09:01.632 PCTime: %FW-6-LOG_SUMMARY: 2 packets were dropped from 10.31.20.36:34640 => 8.8.8.8:53 (target:class)-(ccp-zp-in-out:ccp-invalid-src)
I removed the security zone and indeed i have internet! So i think the problem is solved, but need to get the security zones working...
Regards.
Alain
this command removed the whole access-list, so I recreated it with this line left out. But this did the trick! Thanks alot.
